scootr
Elite Member
- Joined
- Aug 9, 2022
- Messages
- 4,196
- Location
- Temecula California
- Tractor
- Kubota MX5200 HST, 773 Bobcat, Cat forklift
The bucket is starting to resemble a Swiss Army knife
Ken’sYes, everyone should have hooks!
And USA Made ones to boot! (Hint, those are NOT on Amazon).
Those are cool! And home made. Real fabrication deserves a thread, not a $23.99 hook set and drilling 4 holes.Got to be at least 10 thread already on installing bucket/chain hooks..... I oped for home made...
Nice work there. One thing I like about hooks on the top of the bucket is the ability to pull up on the chain using the bucket curl.View attachment 826008
Am I the only one that wants hooks down low on back of bucket much closer to the tractor ?
so much better for lifting heavy objects imo
They would have to be welded on as you did or the bolt heads could cause material to stick in the bucket.View attachment 826008
No, mine is on the back of the bucket. Used an existing hole:Am I the only one that wants hooks down low on back of bucket much closer to the tractor ?
Then welding is the only option on the back of that JD bucket. No way would you want to drill & bolt thru both walls.The back of JD OEM buckets are double walled
