B 2910 Hydro oil level
   / B 2910 Hydro oil level #1
dlabrie
Campton, NH
Kubota B2910
Hi, I just finished the 6th or 7th 300 hour service on my 2001 b2910.
The manual specifies 3.83 gallons of hydro oil after a filter and hydro oil change. The last time I did the 300 hour maintenance, I made a note that the dip stick registered over filling. So, this time I only put in 3 gallons and it still reads just above the fill line.
I drained the oil from the plugs at the bottom of the front and rear transmission case. I replaced both hydro filters and cleaned the transmission strainer.
Should I be worried that I put almost a gallon less oil in?
Also, how does anyone see the oil level on that yellow dipstick! I have to lay it on a paper towel to see where the oil is.
   / B 2910 Hydro oil level #2
Burn it a little
   / B 2910 Hydro oil level #3
Very likely when you drain it there is quite a bit left in that you cannot drain out. A little overfill is not going to hurt anything either. Also, you should run it around a little and get things fully operational after the fill and then top it off. There may be some difference after running it.
