4720h
   / 4720h #1
jpisarzewski
Branson 4720h
Hello all, new used Branson owner here and so far not the best experience for my first tractor. Was told that it’s a 2015 4720h. Plate on valve cover of engine is stamped with a manufacture date of 8/22/2014 and the tractors serial number is CLKD00087. I was told by a dealer that his TYM rep indicated that serial number comes back as a 2009 model (something that the “C” indicates). Would anyone be able to provide any insight on to what year I actually have? I am leaning towards a 2014 due to the engine stamping and thinking that the TYM rep is mistaken? The loader controls are next to the steering wheel and not integrated into the right fender as I have been led to believe from internet research that was a 2015 model change.
Also I have lots of white smoke coming from the exhaust that dissipates once the engine is warmed up. I was originally told when I purchased it was due to the regen system (just the DPF filter) but that since has been deleted and it’s still having the same issue of lots of white smoke that smells sweet until the engine is warm, which is leading me to believe the tractor has a blown head gasket. Does anyone have a machine/head shop near southeastern Michigan that they could recommend to get the head inspected?
Where is everyone ordering parts such as gasket kits for these tractors?
Sorry for the lengthy post and thanks for any info that anyone can provide.
   / 4720h #2
well i can answer part of this, if that unit had an emissions system installed on it at any point is at a minimum a 2014 model but its not a 2015 based on how you describe your joystick setup,
Secondarily no tractor sold by Branson had an emissions system prior to 2014-2015 year models as they were not required by the EPA until then,
as for the serial # thing the TYM rep talked about that's not how Branson did their serial #'s at any point so he's just talking out his a**,
as for the sweet smelling white smoke, yea that would indicate to me a possible gasket issue.
(2) New/Unused Welding Helmets (A44391)
(2) New/Unused...
INOP/NON-RUNNING 2000 Ford F-450 Pickup Truck, VIN # 1FDXF46S9YED80883 (A44391)
INOP/NON-RUNNING...
2018 Chevrolet Impala Sedan (A44572)
2018 Chevrolet...
2015 Texas Trailers 30,000lb T/A Dovetail Flatbed Equipment Trailer (A44571)
2015 Texas...
Kirk-Rudy 630 Stacker and Townsorter (A46877)
Kirk-Rudy 630...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
