Be prepared for a struggle getting the oil filter loose so get your self a good filter wrench. I did a write-up on changing the fuel filters so try to find it. It might save you some guess work because neither of the manuals are much help. Lube points are all over depending on what options you have but those require lubing more often than 50 hours. Most are on the backhoe and FEL.
