Sierraau
Doesn't work. Tried it.Try some spray cooking oil, Pam or equivalent. Or just order a non stick blade.
But does make a mess. This does workDoesn't work. Tried it.
Exactly if you keep the unit in a shop or garage. The temp differential will always keep snow sticking to the blade until the temp equalizes. Fact of life and no coating or plastic will change that. It might help a bit but it will still stick a certain amount.usually early year problem... the blade is warmer then the snow, wax it maybe ?? cool it off with dry ice lol
I bough a Bravo last year it was kept in a heated garage and the snow stick on the skis for a long time before like two months before it stop it was very annoying... I bought some ski skin but I am hesitant to put them on because they cause them to float too much and you get stuck regardless and it doesn't turn as good ... this year I will keep the bravo in the shade and outside see if it helps.Exactly if you keep the unit in a shop or garage. The temp differential will always keep snow sticking to the blade until the temp equalizes. Fact of life and no coating or plastic will change that. It might help a bit but it will still stick a certain amount.
Something I don't do anymore, moving snow or raking leaves. I can sit in the house and watch it snow and read a novel and be perfectly content and watch out the window to see if some idiot goes in the ditch and then I'll get out one of the big M9's and go pull him or her out, for a fee of course and no credit cards, cash only and they hook the snatch strap to THEIR vehicle, not me. I'm not responsible for damage they do to their car or truck and I've yanked some pretty big trucks out of the ditch in the past and my fee increases with the size of vehicle I yank. Mostly 4wd trucks and AWD cars. People somehow think that if they have a 4wd drive vehicle, they can go anywhere. Not the case at all. In fact AWD goes in the ditch easier than a 2WD because 4wd owners are basically stupid and large amounts of snow cause the drive wheels to loose contact with the road and off they go. I get a few every winter. pays for my wife and I to go eat out.... I learned the hard way NOT to hook up a tow strap to a ditched vehicle. I Vee'd a Tie rod once and had to eat it. Not any more. You hook, I pull, real simple and I get to sit in a heated cab tractor and watch your stupidity too. Got a real nice 8 foot wide, power angle plow with guide wheels on it, plus an nice 72" Lucknow rear mount blower I'm gonna sell when I get the time to list them on TH or CL.
No more snow or leaves for me unless I'm getting compensated for it, that especially applies to yanking idiots out of the ditch.
The tractor. is always outside, still a problem.Exactly if you keep the unit in a shop or garage. The temp differential will always keep snow sticking to the blade until the temp equalizes. Fact of life and no coating or plastic will change that. It might help a bit but it will still stick a certain amount.
Do you guys see high moisture warm snow there?The tractor. is always outside, still a problem.
