Two Month Evaluation of BX25
Model Year: 2011
This machine does not seem to be designed by anyone with a lick-of-sense. A. The front loader control handle is too long. If I were some little pip-squeak who needed a ladder to mount the beast it would be different but I'm a pretty big guy. Notice I said big, not fat. Every time I dismount from the right side, I hit the handle and wherever I had the bucket for whatever reason, it gets moved and I have to re-position it. Okay, I can dismount to the left but if I'm up against a fence or wall I don't have that option. Whack - it becomes about 6" shorter. B. The three-point control lever is too far away. Like I said, I'm a pretty big guy. I even play trombone so my right arm can reach clean around big mama and still tickle a rib but when I'm turned so I steer with my right hand and watch the rear attachment over my left shoulder, I can't adjust crap. Also, for me, the action of the lever is counter intuitive. I want to pull back to go down and push forward to come up. - I'm designing a lever extension that also reverses the action. I'll be able to reach it from anywhere. C. And while weʼre on the 3 point hitch, why is there no way to return to a position? You get to the end of a row, lift the attachment to turn for the next row and ??? where did I have it set for the last row? Back to trial-and-error for every row. Now there is a real bright design idea. I only need position control, not draft control. - Iʼll rig up some sort of a gauge to tell what angle the top arms are and visually go back to a point or number. D. The reverse pedal is dumb, stupid, moronic etc. It's in the exact place necessary to tear cartilage in my knee when I'm turned to watch the rear and try to hit the pedal. I'm designing a see-saw like attachment to mount in front of the forward pedal with the reverse pedal under the break pedal. Push one forward and it pushes the other rearward. The break pedal is too high but I'll leave it alone, for now. - I'll probably whack the old reverse pedal. E. The three-point lowering damper knob is too close to the existing reverse pedal. I clip it when Iʼm fishing to find the reverse and then change the setting. - That'll be fixed when I move reverse. F. All the control levers, on both sides, are too far forward. The entire group on each fender needs to be moved back several inches. The two most used are the 3-point and the PTO engage. The others don't even need to be in that location. It's been over 100 here most days. I wear shorts to work. Every time I dismount, one pant leg or the other gets caught on one of the levers leaving me hanging. - I don't know what I'll do about that. Drive naked? G. The little yellow pull stopper on the hydraulic case is designed to let in as much dirt as possible each time you check the level. Nice, real nice! I'll probably make a compression fitted extension to lift the opening higher (makes it easier to fill also) with the threads on the top outside so no dirt gets near the opening. The one on the front axle I can't even get off without some tool to pry it open. This should have a screw cap as well so a wayward stick (with stronger fingers than mine) can't pop it off. H. While I've read that people have a tough time turning the seat around to work the backhoe, I actually have no problem with that. I do think the seat is not designed with the knowledge that most of the work with a tractor is done in the rear and, unless you have eyes in the back of your head, you must turn around to manage your work. This seat makes it difficult and uncomfortable to do that. Although the BX25 is quite capable, I don't think the designers of this tractor thought it would ever be used for real work. Either that, or their idea of real work is not the same as mine. For the price I paid, I should not have to “get used to” or “put up with” anything. They advertise this as a tractor, not an estate toy. It should be able to operate like a tractor within the limits of its size and horse power. Like I said, this is only the two month review. I'm sure I'll find more "interesting" features the longer I use it. Because I was only a working man before I retired, I'll never be able to afford an upgrade or trade for something different so I have what I have. I can, however, make all the “adjustments” that I want to this one.
Pros: Works hard.
Cons: Read report.
