ZTXS4 48 Seat "Springs" Replacement
   / ZTXS4 48 Seat "Springs" Replacement
Update - i took a Dremel and cut the extra pair of springs to where they would be the same height as the OEM "springs" - problem solved. Now I will see the longevity of the rubber caps to see if I need to go back to the drawing board. The seat now latches!
2008 Infiniti G35 Sedan (A48082)
2008 Infiniti G35...
Heavy Duty Forklift Plate and Forks (A50860)
Heavy Duty...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2002 Blue Bird F131612 Bus (A48081)
2002 Blue Bird...
