zetor 7745 hydrualics not working
   / zetor 7745 hydrualics not working #1
cjjans89
zetor 7745
I have a zetor 7745 and I can't seen to get the hydraulic working for the loader or three point hitch when It worked fine when I used it a month ago so I don't know if I have the lever wrong or what any help would b appreciated thanks
   / zetor 7745 hydrualics not working #2
Try moving the 3pt lever, and see if it affect the FEL.
Install a gage in the system before the first valve.
ok i tried that and nothing what do you mean by putting a guage on there is it so i can see if its working or for something else and i dint know if you know a lot about this tractor but there is a lever on the floor that runs everything and i think it has 4 positions and that is what i was think i had wrong but i tried all of them and i cant get it going
   / zetor 7745 hydrualics not working #4
Yes, a gage will tell you if you have pressure, and how much. It can also be used to set relief valves.
well i will def have to do that then when i get it home from the farm is there anything else u may know abouty the hydrualics and why they are not working and thanks for the info
   / zetor 7745 hydrualics not working #6
Can you see the pump? Does it have coupling connector from pump to crank shaft? I assume not out of oil? Can you hear fluid moving through valve or hose?
2022 Club Car...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Root Rake (A48083)
Root Rake (A48083)
4 1/2 150G DRILL STEM 358 JOINTS (A50854)
4 1/2 150G DRILL...
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
1968 John Deere 4020 with 7ft Mower (A51039)
1968 John Deere...
