Oil & Fuel ZDDP additive
   / ZDDP additive #1
magyarbacsi
I usediesel additive in my 5525 to make up for the lack of lubricant in it. I would also like to add to the tranny/tractor fluid such as ZDDP. Would it help or hurt the Tractor fluid if it was added. Since the tractor fluid runs the hydraulics but also the tractor gears, woud such an additive harm the hydraulic pump and the control valves?
   / ZDDP additive #2
Having worked on trucks as a job and equipment on the side, I do believe I have seen every, The greatest product and additive there is. What usually comes out after a while is that it is all BS.
People will spend a lot of money on some additive, personally I would spend the money on the best filter you can find and replace the oil. That works!
   / ZDDP additive #3
the biggest thing I would worry about is how it would effect wet clutches and/or wet brakes.
10' Poly Feed Trough (A50515)
10' Poly Feed...
Best 30' Grain Drill (A50514)
Best 30' Grain...
Case IH 2388 Combine (A50514)
Case IH 2388...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
