Z425 starting problem
   / Z425 starting problem #1
LarryLevet
Hammond, LA
JD4120
My Z425 starts but stops after running a few seconds. Seems like it is not getting fuel but all seems ok. Any ideas?
   / Z425 starting problem #2
What have you done?
What have you checked for?
Check for spark Bad ignition module/coil(s)
Check for fuel (fuel filter, fuel pump, then carb (float, inlet valve, jets, idle circcuit,) if equipped, or plugged injectors
   / Z425 starting problem #3
Not all "ok" if it stops running after a few seconds, maybe check if it is still getting fuel.. If not, why.. fuel filter, bad fuel, ??
If getting fuel, then go to shutoff conditions.. safety switch, ??
What have you done?
Well I changed the fuel filter, changed the plugs and that's about it so far. Changed the solenoid last year. It starts up and then after about 5 to 10 seconds it just quits. Got me confused.
   / Z425 starting problem #5
Do you use the choke ? mine must be choked on cold starts.
   / Z425 starting problem #6
Check the fuel shutoff solenoid. It may be bound up, not opening all the way.
Yes. I have to use the choke every time I start it. always had since I owned the mower.
Is the fuel solenoid easily found or do I have to dis-assemble the sheet metal to get to it.
   / Z425 starting problem #9
Fuel solenoid is part of the carb, usually attached/part of the fuel bowl.
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
