Z-Force 50 vs. GT 1554
   / Z-Force 50 vs. GT 1554 #1
RazedRite
Georgia
I wanted to get a new mower to see if I could reduce the time required to cut my two acres.
Anyone have any input on which of the two cadets I'm looking at could help with that the most?
Thanks!
   / Z-Force 50 vs. GT 1554 #2
Well obviously you are looking at two completly different machines. So lets see if we can lay a little ground work for making some kind of decision.
What kind of land do you have? Is it hilly with lots of dips or fairly flat? Are you going to be towing anything with your new mower? Do you want the ability to have implements attatched?
It's a mostly flat lot with a few gentle slopes. I don't see any need for much towing if any. And no attachments will be needed except for maybe a bagger or something of that sort.
I mainly am concerned about cutting down on the four hours it takes right now with my Craftsman (42").
   / Z-Force 50 vs. GT 1554 #4
Well if you are only planning on cutting grass with the unit then there is no question that the Z-Force would be the prime choice here. It will run circles around the GT 1554 as far as time it takes for cutting and will also give a better cut because of the pivoting axle and floating deck. Go with the zero turn, you won't regret it.
   / Z-Force 50 vs. GT 1554 #5
I've got the Z-Force 50 and a CC 2180. Love them both, but the Z-Force is head and shoulders above the tractor when mowing.
Z-Force is a "one trick pony", mowing only, get the tractor if you need to pull a wagon around after mowing, etc.
   / Z-Force 50 vs. GT 1554 #6
   / Z-Force 50 vs. GT 1554 #7
SO you can't pull any cart with the z force
   / Z-Force 50 vs. GT 1554 #8
   / Z-Force 50 vs. GT 1554 #9
Can't or CC doesn't want you too? /forums/images/graemlins/grin.gif
There is no hitch on the ZF; I'm guessing CC either is avoiding some legal issue or wants to keep the transmission stress minimized.
That said, I know at least one thread where somebody bolted on a hitch plate.
For a light cart, not going long distances or up & down hills continously (or for that matter not going up steep hills for safety's sake), I can't believe there'd be much more wear & tear than mowing stresses.
   / Z-Force 50 vs. GT 1554 #10
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2022 Club Car...
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
