you can change oil in k61 hydro's on jd lx178
   / you can change oil in k61 hydro's on jd lx178 #1
kdronet
lx 178
tuff torq k61 hydro's oil can be drained and new oil put in if you have an old model jd 100 or 200 series mower check to see if it's the k61 model if its not pulling like it should or is slowing down after mowing for a while it could be the oil needs changing tuff torq has all the info you need to get this done right filter is in trans and can not be changed my 94 model jd 178 began losing ground speed at about 450hrs changed oil ran for 2-3 mowings then changed again takes maybe 3 1/2 qts. changed oil again at 925hrs but had harder time getting air out of system than previous time but is running fine now just finished mowing my 1.9 acres and i must say i can not come up with a single fault to trade in mower for newer one in 17 years i guess it's become a good habit!!!!!!:cool2:
2008 Ford F-750 SD Roll Off (A50860)
2008 Ford F-750 SD...
2025 Swict 60in. Bucket Skid Steer Attachment (A50322)
2025 Swict 60in...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
2017 John Deere 650K LGP Crawler Dozer (A50860)
2017 John Deere...
