Rear Blade York Rake? BoxBlade? or Rear Blade??????
   / York Rake? BoxBlade? or Rear Blade?????? #11
amitysanimal,
Let me know how you like the TSC box blade. Do you know the weight? I'm thinking about that one when my BX gets in.
Ed
I called TSC and of course they don't have one in stock, they only have the 6' BB and that too big. My B7100 is about 46" wide so a 4' will work but I was thinking of going to a 5' because its only 20 bucks more. I hope the TSC BB are OK, I have called all around and the tractor dealers want close to $800.00 for a Landpride 5' BB. I KNOW what the wife will say about that purchase, no way in heck. TSC said they might get a 5' blade in tomorrow, thats $419.99.
Do you think a 5' blade is too much or should I go with the 4" blade. My tractor is cat 1 with cat 0 dimensions. The cat 0 4' blade would fit better and is $398.63. What should a fella do???????
amitysanimal
   / York Rake? BoxBlade? or Rear Blade?????? #13
amitysanimal:
For your stated uses I think a 5' box blade would be a little large. If the 4' BB fits your 3 point hitch better then that is also another important consideration. TSC box blades are considered somewhat light by some of the readership; but you can always add weight. Jay
   / York Rake? BoxBlade? or Rear Blade?????? #14
amitysanimal
With a 16 hp Cat 0 tractor, I think there will be times when even a 4 foot box will stop you cold. I would not go for 5'
Andy
Sounds good, I'll have them get me in a 4" BB. They said it could take a couple weeks, but it sounds like thats the way to go.
   / York Rake? BoxBlade? or Rear Blade?????? #16
I use a landscape rake w/ wheels to groom the gravel and a rear blade to move snow on our ~ 800' drive. 7" width for each behind a Kubota L4310.
   / York Rake? BoxBlade? or Rear Blade?????? #17
I ran into the same problem at TSC with them not having the one I needed in stock. I went home and ordered a United Box Blade online that came with free shipping.
Pretty nice box blade that has the curved cutting edge and forged ripper shanks. Best part is that if I wear it out over the years, I can rebuild it by replacing the cutting edge and the rippers and it is like new again!
   / York Rake? BoxBlade? or Rear Blade?????? #18
Good idea on going with the 4 ft boxblade. I bought a used 6 ft boxblade for my CK35 but in hindsight should have gotten a 5 ft; this would be just a little wider than my tire tracks. My boxblade has front and back replaceable curved cutting blades. As other posts have mentioned go with a heavy one as it will work better for you. Have a 7 ft backblade as well but do not use it often, mostly use the boxblade.
   / York Rake? BoxBlade? or Rear Blade?????? #19
The rakes are best if you are trying to clean up a gravel driveway without removeing the gravel itself. I use mine to sweep away logging debree like pine bark and small sticks that have fallen off the log trucks. it can collect the bark and still stay on the grownd where a box blade can get a small stick under it and it will no longer be on the grown gradding.
before using the rake
after the rake
   / York Rake? BoxBlade? or Rear Blade?????? #20
I know that this is late... but that job ^^^ was pretty good. Rake is one on my lists to get :D.
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
JOHN DEERE 5105M TRACTOR (A58375)
JOHN DEERE 5105M...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
1292 (A58374)
1292 (A58374)
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
NEW Fork Extensions (A59000)
NEW Fork...
