YM 1700 Air Intake
   / YM 1700 Air Intake #1
HLP
Florence Alabama
YM 1700
I noticed a reservoir in front of the air filter housing. Pulled the lid and it was empty. The line out of the bottom leads into the air intake manifold. What is this for? Should there be some kind of additive that a diesel needs?
   / YM 1700 Air Intake #2
I believe that it is the thermostart reservoir. You add diesel to it when it is cold outside. Most of the systems work by turning the key backwards for about 15 second right before turning to start. Mine has a push button, but I think that it was added by a previous owner. A little glow plug-like device flames the fuel as it drips down warming the intake air. Helps the motor start faster in cold weather.
Craig
2017 Ford F-650 (A53422)
2017 Ford F-650...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
40' CONTAINER (A51244)
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500 4x4...
2023 Yamaha R Max XTR  (A52384)
2023 Yamaha R Max...
