XU6158-58HP
   / XU6158-58HP #1
4tillingdirt
nc
N/A
You guys think this tractor is way too large to use around the house - sowing and plugging yard, putting out mulch?
   / XU6158-58HP #2
That's a pretty heavy tractor. I wouldn't use it for much yard work if you have a nice, finely groomed lawn. For rough cutting field grass, it would work fine. I occasionally run my tractor across the lawn but try to do it only when the ground has a few days to dry out after rain. If the ground is soft, it will leave impressions in the lawn. I plug my lawn with my zero turn.
Edited to add -- I have R4 Tires. You can do better on lawns with turf tires.
   / XU6158-58HP #3
How much acreage?
It’s fairly large and not easy to maneuver in tight spots.
I have 60” forks I use most of the time on mine, and it’s a recipe for damaging anything nearby.
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
