X324 - Changes 2007 vs. 2008?
   / X324 - Changes 2007 vs. 2008? #1
rxman
Were there any significant changes from 2007 to now for the X324 lawn tractor?
Dealer dropped mine off a couple days ago and I noticed it has a 4/07 build date. I bought new and the unit hasn't been used at all for cutting. The blades and deck are clean.
   / X324 - Changes 2007 vs. 2008? #2
What does the deck look like? If you have the rotatable gauge wheels with a 2 belt deck drive that is the new style. I belive 2007 and 2008 should be the same. On your build date they build alot of them then warehouse them and then ship them out whenever a dealer orders one. Hour on the tractor is what you want to look at. That is what determines what use has been on the actual machine.
The hour meter showed 1.0 hrs on it. I figured it had been moved around the lot but you could tell it hadn't cut grass.
The deck is the Edge Xtra but the wheels are fixed. I thought the 48 and up had the swivel wheels.
Box blade (A50860)
Box blade (A50860)
UNUSED 2-Pack Blue Ratchet Strap Set (A50860)
UNUSED 2-Pack Blue...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
Big Machine Fork Attachment (A50860)
Big Machine Fork...
2016 Chevrolet Traverse LS SUV (A50860)
2016 Chevrolet...
