I'm not sure how much I mow, probably between 1.5 and 2 acres.
How much FEL counterbalance weight in the form of filled rear tires, wheel weights and/or a Three Point Hitch mounted implement do you use during Loader work?
The BX has foam filled tires and with the mower on it is VERY stable on slopes.
Traction is the limitation for the BX.
So I've owned a BX2350 for a little over 10 years and have 760 hours on it. It does what I want but I often wish when I'm doing end loader work that it had a bigger bucket. I also feel the front tires are too small at times. I mow with it about half the time and have some side hills that push my comfort level on the BX but it gets the job done. I'd go with a 60" mid mount deck on the B. The other half of the hours I'm moving dirt, gravel, and snow. My driveway is paved and about 600 feet long. Sometimes we get a lot of snow, sometimes almost none. I also would like the better road speed of a B tractor.
Would one of the smaller B tractors, I'm thinking either 23 or 26 horse increase the bucket size enough that I would notice the difference? I couldn't find the specs on bucket capacity. Would it seem too big when it comes to mowing? It doesn't look like the turning radius is that much bigger but they spec that while using the brakes to make it turn tighter on the B tractors. With loaded tires would it seem as stable on the hills as a BX? I'd like to get into a used B for 5k with a trade in on my BX but I don't know if that's possible or not. Thanks in advance for the answers.
I think the bug has bit you. Probably not going to be content until you have a bigger tractor. Most of us have been in the same position.
