Rake Woods LR800 rake, too beat or ok??
   / Woods LR800 rake, too beat or ok?? #1
hbracerx
PA
Kubota B3200
I found this LR800 for sale locally on craigs list. I'm pretty much a tractor newbie. Have a Kubota B3200. I'm having a bank dug out to put in a garage, will have the contractor get the material where I need it and use the tractor to get it right. Will need a rake to get out some of the rocks (there will be lots of them). The tines on this look fairly tweaked to me. Is it worth taking a look or should I pass? Tractor doesn't currently have rear hydraulics but it will soon (hopefully).
I'd appreciate any thoughts. The pics are kind of limited.
WOODS 8 FOOT LANDSCAPE RAKE
Thanks!
Tom
   / Woods LR800 rake, too beat or ok?? #2
I'd jump on that one fast. It's older but looks to be in decent shape( may need a few tines replaced) and with the hydro angle and flip down blade I doubt it'll last long.
Matt
   / Woods LR800 rake, too beat or ok?? #3
And it's got the gauge wheels with it too, which are nice to have.
   / Woods LR800 rake, too beat or ok?? #4
I think you could straighten most of those tines to work well enough. Hook the tines with a large pipe wrench and bend them back into alignment. A little heating and tweaking and welding and you would have a very nice rake.
I would consider adding the offset cylinder too.
About the rocks, you might also consider a rock bucket for your purposes. From your description you want to rake the rocks out of the dirt pulled out of the embankment. A rock bucket to sift through this dirt might work better.
I went to look at the rake today. Unfortunately it was a bit too "used" for me at the moment. The grader blade was bent in the center easily 2 inches, there were probably 8 straight tines on the whole rake, the bracket for the power angle was bent (and that was some thick steel), the cylinder had a decent amt of pits/rust, etc. If the blade hadn't been bent, I may have considered it. I haven't gotten my garage built yet so working on things is much more difficult than usual (most of my tools are buried from the move). For someone looking for a heavy rake that needs some tlc, it's probably worthwhile. The search continues...
Tom
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
