Woods BB720 for NH TC45D
   / Woods BB720 for NH TC45D #11
John Bud,
Thanks for stopping by and giving us an update! Does the BB600 come with a stumpjumper as standard equipment or optional? Also, are you running the unit with front and rear chains and if so, do you know the weight of the unit with all this extra hardware?
Russ
   / Woods BB720 for NH TC45D #12
John Bud,
Thanks for the input. You're original posts were one reason I wanted the medium duty cutter. I wished I hadn't let myself get talked out of it. Not that I have had any problems with the standard duty. I just like knowing the stuff I own is tough.
--Brad
   / Woods BB720 for NH TC45D #13
Russ -
My 3 Pt hitch capacity is 1635# (24" aft of hitch). I don't think hooking on a BB600 at over 1000# would be smart on my machine. I briefly considered it before I knew how much it weighed, but one look at it and I knew it was overkill for what I needed. I'm not looking to start a brush hogging business, which seems to me what the BB600 / BB720 are suited for. I only occasionally cut 2" trees. Generally, for something that big or larger, I get out the chainsaw, or knock/pull the whole tree over (and get rid of the stump at the same time).
What kind of stuff are you mowing? How much of it? Remember, once it's been cut once, the next times are much easier (as long as you don't wait a few years between mowing).
John Mc
   / Woods BB720 for NH TC45D #14
The "Stump Jumper" is what I call the blade attachment hub. It is not optional. I don't use the word "standard", as it is anything but standard fair when compared to most competitive cutters. For comparison, one of my tree farming buddies has a 72" KK. His "stump jumper" is about 1/2 to 2/3 the diameter and thickness of mine. He also has to borrow my Ox/Ac torch to get the blades off. I use a 5/8 inch wrench. But I digress...
The raw weight of the cutter does not scare me. I am religious about keeping the back wheel on the ground when it is being transported between areas. I would be willing to bet that my tractor with the BB600 <font color=orange>used the way I use it</font color=orange>, will be in better shape than one with a 750# cutter that is transported with the cutter "up" over bouncy trails. Just my personal thoughts.
I do have the front and rear chains. My dealer didn't seem to charge me for them. At least I don't think it was an extra line item. I would guess that the chains are about 100#, but the front and rear metal guards you are replacing must weigh 50#.
Someone else (sorry, I can't see the post from here!) stated that they only have 1600-1700 # of lift on their tractor and they don't cut thick stuff often. I agree that I would not think a BB600 was a good fit for them. A BB60, or equivalent from the other respected brands would be acceptable.
To reiterate, I cut trails on my 240 acre tree farm. I only have weekends and holidays to do it on so I require a cutter that won't let me down when I HAVE to use it. I also have lots of branches, fallen trees, and granite rocks that are frost heaved (spelling?) every spring to contend with. So, I don't have time to pre-walk the trails and hand clear the big obstacles. Nor the inclination as we are in one of the deer tick hot spots! Side note here: it is amazing how much of that stuff is new every spring, summer and fall. If I didn't know better I would swear that the deer and bears are bringing it in just to piss me off!
Anyway, the "hundreds" series is overkill for most compact tractor users. The "thousands" series is overkill for all but highway departments and such. The "tens" series is honestly tougher than most low cost medium duty cutters and has the nice features of easy blade removal, built in dip stick on the gear housing but not a slip clutch.
Here's a photo of the tractor holding the cutter on day 1.
Have Fun!
John Bud
   / Woods BB720 for NH TC45D #15
John Mc and John Bud,
Thanks for the additional comments. After reading both responses and rethinking my anticipated use for a cutter, I will revisit the BB60 or BB72. Right now, I'm running a 20 year old Woods 5' unit doing orchard/field mowing but its showing its age. This year, I plan to start doing some clearing/trail making throughout my woods and sugarbush which has started the process of looking for a replacement cutter. Most material to be chopped is seedling to sapling size.
Whatever unit is picked, I know it will be a Woods. I'm hooked on their blade attachment setup.
Russ
   / Woods BB720 for NH TC45D #16
<font color=blue>...I'm running a 20 year old Woods 5' unit ... I'm hooked on their blade attachment setup...</font color=blue>
I wouldn't get pigeon-holed into letting one particular item keep me from choosing other brands...
Unless you're doing "brush hogging" for a living... the average person will never get the opportunity to even change any blades... /w3tcompact/icons/smile.gif
Just curious...
How many times have you changed the blades on your Woods rotary cutter...? /w3tcompact/icons/wink.gif
   / Woods BB720 for NH TC45D #17
John,
Looks like my first reply got lost, so I'll try it again. When I first got the cutter, the blades needed changing. They were a nightmare to get off because of the rust on the blade pins ( I had a post on this somewhere on the forum). I keep two sets of blades, one for field/orchard cutting and one for taking into the woods. If the woods set gets too dinged up, off they come for touchup. The number of times this happens in a year varies. In addition to this, I will remove the blade pins at least twice a year to grease them. To some this would be considered excessive but since the cutter is stored outside, I do not want a repeat of my first episode. Although Russ and Rust are close (at least alphabetically) we do not get along /w3tcompact/icons/wink.gif
Russ
   / Woods BB720 for NH TC45D #18
john bud:
I was curious as to what brand of box blade you have attached to the back of your kubota? Can you raise the scarifier by hydraulics, or are they manual?
Thats a nice looking package you have there.
   / Woods BB720 for NH TC45D #19
Well Golly Rus...
I'm gonna eat my words... you are one of a kind... /w3tcompact/icons/grin.gif
That is different... maybe a little overkill... buy hey, you're the one doing it... /w3tcompact/icons/wink.gif
I have changed a number of blades over the years... but believe me not by choice... my buddies seem to think I have all the tools... /w3tcompact/icons/blush.gif (I'm really the only one who's got the 6' breaker pipe /w3tcompact/icons/smile.gif)
   / Woods BB720 for NH TC45D #20
Noticed you like the Woods type of blade fixing: Groove machined into the blade bolt, a little "chip" stamped plate and a 1/4" tab bolt. Easy to get to and certainly does not take as much brute force to loosen. Any other supporters before we tell the bolt factory what to make for First Choice ?
You seem to be one of the really more informative people on TBN. My compliments. I really enjoy reading your messages. Question: Once I knew a MIller Equipment in Delaware Ohio: is You, Family or no Relation ?
Happy Hobbying !
2004 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
2012 BIG TEX PIPE TRAILER (A50854)
2012 BIG TEX PIPE...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
1955 FORD COBRA REPLICA RACING CAR (A51222)
1955 FORD COBRA...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
