wobble fan blade for Mahindra 2816
   / wobble fan blade for Mahindra 2816 #1
BC4
Cartersville, GA.
Mahindra
Hi All,
My Mahindra has developed a wobbly fan (cooling fan). Any ideas what the problem is?
I have about 450 hours on this tractor with very few problems.
Bob
   / wobble fan blade for Mahindra 2816 #2
HST I assume, the plastic fan is in a position where it is vulnerable to damage from sticks and brush. Examine it to see if it is cracked or split, or has deformed to a degree. If it's not causing imbalance and resultant vibration, and still moving air it might not require immediate repair.
   / wobble fan blade for Mahindra 2816 #3
Continued operation with an out of balance situation will be hard on bearings. A cracked fan blade coming off at speed could be most interesting, probably dangerous. Careful inspection is in order.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
71053 (A49346)
71053 (A49346)
