Wireing set up on a john deere 111
   / Wireing set up on a john deere 111 #1
Brewmaine
Maine
John Deere 111
Is there anyone with a John Deere 111 that could do me a favor I need a few photos taken of how your wiring set up looks to compare with mine to see what I'm doing wrong. Im not getting any voltage on the side of the solenoid going to the starter and I already replaced it so I think my connections may be messed up
   / Wireing set up on a john deere 111 #2
Starters are wired as follows:
Bat+ cable to large terminal on solenoid. (Live always)
Switched + from ign switch is small wire (Live in start position on ign switch)
2nd large wire/terminal to motor. (Live only when solenoid is energized, causes starter motor to spin over engine.)
Thanks I found where the problem was. The person I bought it from had replaced the seat and seeing the new seat didn't use the shut off feature he left the plug under the tractor just dangling leaving the whole wiring circuit broken until I tried putting a jump wire on the two wires in that plug closing the circuit. Then tried it and it started right up. :)
   / Wireing set up on a john deere 111 #4
Got to love those sensors!! Anymore its the first thing I check i have a few extras just in case.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2020 JLG 1732 4x4 Rough Terrain Telehandler (A49461)
2020 JLG 1732 4x4...
71061 (A49346)
71061 (A49346)
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
