Wire Rope or Cable, whatever you wish to call it
   / Wire Rope or Cable, whatever you wish to call it #11
Everyone pay close attention:
Prokop is a very smart man.
Anybody not afraid of a hanging tree should stay in the house.
   / Wire Rope or Cable, whatever you wish to call it #12
Except that Prokop cut the SUPPORTING tree. Which means he was standing under the tree that was hanging....
I have a couple of hanging trees. I can only think of a couple of ways to do it. I am scared to do it so they continue to hang since they are out of the way. I have been hoping Momma Nature would take them down but so far she has not had the time. She did bring down a big sweat gum that was bent over last week. I was going to cut that gum tree down this fall or winter but Momma did it for me. I wish she would take down the hangers. I think I'm going to girdle one of them, cut some wedges out top and bottom to see if Momma can take the tree down with a little help.
Short of a crane, its do it this way, use heavy equipment to push/pull, or use a cable/strap/winch to pull the tree as its cut. None of those approches sound real fun... But if momma fail then its cable, cut, and pull with a winch.
Later,
Dan
   / Wire Rope or Cable, whatever you wish to call it #13
MikePA said:
I'm not a professional treeman, but I thought the way you cut the tree determined where it fell?
I have hired pros for the really tough tree removal jobs. They always climbed the tree and dropped it piece by piece.
   / Wire Rope or Cable, whatever you wish to call it #14
Hhhmmm...
I wasn't paying attention...
Holy Cow!!!
OK. Prokop, You're smart enough to be scared, but PLEASE take a course before you cut too many more trees.
A hanging tree can kill you. I have a ton of them on my 36 acre woodlot. I should say I had a ton of them. Most of them got knocked down last week by my tractor. I was able to push almost everyone of them down sideways. You really need to be careful if they are dead. The tops snap off and pop back at you.
   / Wire Rope or Cable, whatever you wish to call it #16
When I was in fire co rescue school we were tough to put a few fire coats on cable to "slow it down" if it broke but we allways stayed out of line of cable.
on pulling hangers down some times a pivey at the base pulles around works wonders spinning away the support tree. the other way i have n tangled is wrap a chain around leaner 5 or 10 times and pull gently with tractor to spin trunk again away from the one its is stuck in
tom
   / Wire Rope or Cable, whatever you wish to call it #17
Took one down yesterday. Hard to do in a suburban setting but on acreage, safest way is to drop another tree into it. I had a leaner toward one that snapped off in the wind a few weeks ago and got hung up 30 - 40 feet up. Both went down clean.
   / Wire Rope or Cable, whatever you wish to call it #18
Later,
Dan
I dont pretend to be smart - ask my boss or my wife:D
But there was no other way, cutting down the top tree would hang it even more IMHO - and cutting chunks of it when it is hanging could eventually let it fell on the other side - and on the barn.
But I was out of the harms way, cutting frrom the side and only the blade was under the tree; from all my stupid actions I ever did I would scale this as 85% safe:)
I think the stupid way would be to try to get down just the hanging tree by climbing up and cutting of some branches - which is waht my friend suggested and I refused.
Sometimes you can use your bucket and a chain to lift the hanger off the ground and pull it back so it will fall. Just make sure that you have a lot of weight on the rear end to hold you down.
Scotsman AFE400A-1H Ice Machine (A50860)
Scotsman...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
(1) Push Blade and (1) Disk (A50860)
(1) Push Blade and...
1266 (A50490)
1266 (A50490)
