handirifle
Veteran Member
OK so I took my splitter cylinder apart today. Well, I just took the end bell off. So here is a link to and end bell that looks like mine and is same size.
http://www.agrisupply.com/grizzly-rod-cap/p/102121/
I measured mine and the piece of the cap that holds the O ring measures 3.98" and the rod measures 1.499", so I am assuming 4" bore and 1.5" rod. Are the bolt hole openings pretty universal?
Also since it's open should I order a new seal kit? Seems like it would be wise.
Will any kit for those sizes work?
Also in the end bell there is an O ring (for the cylinder), and what appears to be two seals for the shaft. The shaft seals are the lip type and appear to have a 1/4" thick metal spacer between them. Is this correct, or is it part of a seal?
Also appears the shaft seal on my pump is leaking too. Will I be able to order a seal for that too. There is a hydraulic shop in town, about 30 miles away, would they likely have the parts, if I give them the part number?
