will it take off?
   / will it take off? #981
Egon said:
Ground effect sturgeon fishing platform [Sea Monster] as seen on the Caspian sea.:D
And from that picture Egon, one can clearly see that the rearward velocity of the water is preventing the necessary lift to cause the plane to take off. It's practically sitting still (at least on my uncalibrated monitor).
Cool plane, weapons on the top?
   / will it take off? #982
Yeah, right! Sea monster &*($%# ^(*&%
They "fly" these things over flat land too. Can't get up out of ground effect to get over much of a hill or obstruction so you need to have a good map with radio towers and such located.
The Russians use these things to cross parts of their enormous land mass like we use trains and trucks.
Pat
   / will it take off? #983
Uh, technically not an airplane.
It can't get out of ground effect and go higher. It just scoots along in ground effect. It is a cargo hauler. Due to ground effect they are pretty efficient and fuel economical. This one at the Caspian is intended to land and take off from the water. They have land based versions as well.
No, those aren't weapons.
This baby IS too large to put into Eddies pond.
Pat
   / will it take off? #984
patrick_g said:
I think you need to read it again. You were doing pretty much OK till you said the part I left quoted above.
Ground effect DOES NOT require the aircraft to be overloaded before it happens. Ground effect will, in fact, reduce the likelihood of a stall, provided you don't mind flying along within a couple wingspans of the ground. Ground effect so reduces drag and enhances lift that the near stall that is induced to make a good power off landing is prevented and instead of settling in nicely the plane (catches a balloon) just floats down the runway as if being held aloft by a tractor beam (not related to THAT kind of tractor.)
One of the dangerous down sides of ground effect is that it will tend to "trap" an overloaded aircraft at takeoff at a low altitude (within a couple wingspans of the ground) by providing extra lift and reduced drag ONLY when the A/C is close to the ground. The unlucky pilot of the overloaded plane can't get above ground effect, not because it holds him back or down but because it is what got him up there and without more lift than the pane can muster in "free air" the extra weight can't be lifted.
There is nothing wrong with using ground effect for beneficial purposes so long as you don't let it get you into trouble. The Russians have huge ground effect cargo carriers that operate like an aircraft but can't get above ground effect. They are very efficient but fly quite low. There are also recreational flying boats that don't get out of ground effect and do not require a pilots lisc.
Ground effect is interesting but NOT INVOLVED in our amphibious plane vs the retarding current experiment since in order to be in ground effect you need to be airborne and that requires sufficient airspeed to lift off which is not provided by the water current.
I do second your comment re the fish and in their behalf I suggest a weir would be needed to keep the fish out of the intake zone of the impeller. Since the inrush current is much more diffuse than the output current the weir (fish protective strainer) will not have to be very far from the impeller making it easier to construct, position, and pay for.
Pat
I was just paraphrasing this exerpt from the wikipedia site...
"'Wing in ground effect' during take-off is thought to be a cause of many aircraft accidents. A small plane loaded beyond gross weight capabilities may be able to take off under ground effect, thanks to the 'artificially' low stall speed due to the decreased induced drag. But it may not be able to climb beyond a certain point. Once the pilot climbs out of ground effect wingtip vortices will form, the wings will stall, and the aircraft will suddenly descend - usually resulting in a crash."
It sounds like the overloaded plane actually can get a little altitude since it takes a few seconds for the vortices to form.
   / will it take off? #985
If Eddie only had flying fish, they could go airborne and lower the level a tad and increase the air cushion above the magic water. Keeping them up may be problematic...
Jim
   / will it take off? #986
I can say that I have been in ground effect many many times and never came close to having it lead me anywhere near a stall.
I'm not saying it isn't possible or that on-line user contributions to encyclopedias are ever less than perfect, just that in quite a variety of aircraft and simulators I have been in and out of ground effect many many times and never had that experience. I'll accept that it is possible and that my limited experience mislead me.
Pat
   / will it take off? #987
Ground effect?? I have experienced it many a time on both
skis and bicycles. At no time was the end result pleasant as the flying body came to an abrupt halt on less than feather soft conditions.:( :( :(
Now flying fish, did not Thor Heyerdahl and his Kontikki companions breakfast on them on a regular basis??:D :D
   / will it take off? #988
Yes, so they reported in the book. It is not unusual. Lots of cruising yachtsmen take a turn on deck to pick up the nights flying fish harvest. The fish do their gliding act and if they happen to knock themselves out or kill themselves colliding with the deck house, oh well, free food. More than one boat cat has enjoyed the bounty of the sea.
One guy reported being rudely awakened by having something wet flapping about on his face. Seems a flying fish came through an open port light and landed on the sleepers face. He imagined slithey tentacles preparing to drag him to a watery demise before he figured it out.
We used to see flying fish every so often off the coast of SOCAL, some pretty darned big.
I too have experienced ground effect while riding a fast bike. First I experienced dog effect followed by a brief flying experience, ending in considerable ground effect. Why would a big dog run under your front wheel?
Pat
   / will it take off? #989
Pat
Being overloaded doesn't cause ground effect, it causes crashes. Ground effect allows overloaded planes to get just high enough that when they stall is a true crash instead of just a botched take-off. You don't seem like the kind that would try to fly an overloaded plane. Therefore, it doesn't surprise me that you haven't crashed because of ground effect.
As I understand what our semi-reliable resource, Wikipedia, is saying; ground effect allows overloaded planes that otherwise would not fly to get off the ground. Once the overloaded plane attempts to climb beyond 1 or 2 wing spans off the ground, no ground effect, no lift, the plane stalls, the plane crashes on the border between US and Canada, the second definition of ground effect as described by Egon takes over, and we have a lengthy discussion of where to bury the survivors.
   / will it take off? #990
Pat
I don't know, but little brothers do the same thing.
I swear it to this day, Mom! I was just riding straight down the driveway and he jumped out from behind that tree right in front of me.
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
KBH 25T Tender (A56435)
KBH 25T Tender...
16ft T/A Flatbed Trailer (A55758)
16ft T/A Flatbed...
2025 GPS Equipment Trailer (A56858)
2025 GPS Equipment...
PNEUMATIC GREASE UNIT (A58214)
PNEUMATIC GREASE...
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
