Backhoe Will it Fit
   / Will it Fit #1
C'ville Dan
Will a Kubota "L" series 3pt. backhoe #BL4690 fit on a Ford New Holland 1920
Tractor??
   / Will it Fit #2
If it is a 3 point, then it should fit any three point cat 1 tractor. My neighbor has two different size Kubotas and switches his backhoe between them. I have hooked up to many of his tools with my Fords so I would think his Kubota hoe would fit on my ford. The Woods backhoe I have will go on any three point hitch. There will likely be some ajustment to the top link. In some cases moving the lower pins on the backhoe mount will be needed. My 1710 can not use the top link setting as my 2110, 1920 is same setting as 2110, but those are minor adjustments.
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
1263 (A50490)
1263 (A50490)
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
