Will a 72" deck fit a ZD1211 that originally came with a 60" deck?
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #1
90cummins
Veteran Member
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
Just wondering if they are interchangeable.
90cummins
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #3
Doesn’t the 72 have the wider front axle as well?
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #4
The 72” frt axle is Wider.
Has anybody priced a complete 72” SD deck assy ?
I’m wondering how bad expensive they are .....
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #5
I kinda doubt it’ll work. Just because both options were offered doesn’t mean everything else is interchangeable. Is there room to put the deck in for starters. A 72” has 5” longer blades so the deck is going to be deeper to clear them. My 72” ZT has a 59” wide wheelbase. I kinda doubt they’d stick a 60” deck in the same frame and only let it stick out 1/2” per side.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #6
I believe it will. I have a 72 RD on my ZD1211. I don't think Kubota would make different machine and ship to dealer that will accept only one size deck. I bought a new F2690 and it has a 60" SD with mulching kit which the dealer had on hand and had to wait over a month till the machine arrived to then install deck. I believe dealer gets the machine and installs the deck. Just not seeing making different power bodies for specific deck. :2cents: when different sized decks are offered.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #7
My father in-laws ZD1211 60 SD “looks” the same wheelbase as both my 72 machines.
I hadn’t physically measured them tho.
I know my front axle is 7 Wider than a 60 cut.
The rears are the same width / same transmission.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #8
The ZD1211-60 and ZD1211-72 have different and unique part numbers for the main frames. That leads me to believe that 4570Man is correct, the 72” deck will not fit a ZD1211-60 chassis.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #9
Dealers do not install decks on zeroturn mowers, they arrive crated with decks installed. Front deck machines are a completely different animal, there are uses for them that do not include mower decks. Additionally F-series attachments are by definition in front of both axles, not between them.
   / Will a 72" deck fit a ZD1211 that originally came with a 60" deck? #10
Wheelbase length must be a little different ?
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
Headache Rack (A50860)
2014 INTERNATIONAL PRO STAR (A50854)
2014 INTERNATIONAL...
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
2013 ACURA ILX (A50324)
2013 ACURA ILX...
