Why does my loader only raise after switching work ports on a 2 spool valve?
   / Why does my loader only raise after switching work ports on a 2 spool valve? #11
Look up this link. It says that the loader is a floater and the bucket curl is a regenerative spool. If so, if you have the regen lines backwards you will probably get the trouble you are having, as a regen circuit takes oil from the retracting side and dumps it back into the extend side so that if you had the lines backwards it would probably tend to lock up the cylinders. I stand corrected if this is not the problem and will not bug you again. http://www.huscointl.com/media/pdf/construction/9210.pdf
Steve
   / Why does my loader only raise after switching work ports on a 2 spool valve? #12
Ok Tom, I get it. We are not to snow plow savvy here in Georgia.
MarkV
2002 International 9200i Truck (A56438)
2002 International...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
