Why did I buy this thing?
   / Why did I buy this thing? #1
oldpilot
Bronze Member
Mahindra
Mahindra 1626 HST.
Yeah, it was cheaper than a Kubota, but really, I have never seen a piece of machinery so badly engineered. The manual tells me to check the engine oil every day. What a laugh! I have to raise the hood, remove the starboard side panel, raise the bucket to the ceiling, thread a trouble light past the loader arm and hydraulic cylinder, and SEARCH for the dipstick. Taking it out is hard enough, but find the hole with my left hand and guiding the dipstick into the hole with my right hand, all the while being careful not to dislodge the trouble light, is one of the most aggravating tasks of my life. Then of course I have to put it back together again. It takes me, all in all, about half an hour. Ridiculous.
And that's hardly the only bit of bad design. I rarely get down from the cockpit without accidentally activating the left turn signal. Nothing is placed logically to my mind. From 1975 to 2019 I enjoyed a Japanese Bison tractor with International Harvester sheet metal (IH 284). How I miss it! How I wish there had been a shop closer than 50 miles so I could have kept it operating. (It went into the shop only once in forty-four years. Mahindra Baba has been there twice already.)
   / Why did I buy this thing? #2
Sorry to hear about the troubles. A good thing to research prior to purchase are the every day tasks and the services on tractors. Luckily YT has made that task fairly easy.
   / Why did I buy this thing? #3
Mahindra 1626 HST.
Who checks the engine oil every day on their privately owned cars, or tractors?
Mahindra owners?
   / Why did I buy this thing? #4
If this is the same, I can agree about the PITA engineering.. Good tip about painting the handle (and maybe the top of the tube?) for better visibility.
edit: This guy modified his tube and dipstick for easier access: Mahindra 1626
   / Why did I buy this thing? #5
Now that's compact tractor if has to struggle to check the oil. :oops:
   / Why did I buy this thing? #7
I check mine when I notice a drip on the garage floor (none so far) or every 10 hours when I grease. However mine can be checked without moving anything. It is easier than my truck. Sell that piece of junk and get you a tractor you want to work on. Take what you have learned and make a more informed purchase!
   / Why did I buy this thing? #8
That oil filter is going to be fun to change as well!
Hey Kubota isn't all great....my X1100C HST filter is a PITA to get to (remove skid plates). Also the oil filter has a plate I have to remove..
   / Why did I buy this thing? #9
Mahindra owners?
I check my oil before I start my tractor for the first time every time I use it. This is not every day because I don't use it every day.
Do I do this on my car? No I don't. I probably should. But my tractor is far more important to me than my car.
Luckily I don't have to go though what the OP does to do something that should be the simplest of tasks.
   / Why did I buy this thing? #10
Oh wow!
The Mahindra lovers will soon be right along to bash you!
197637 (A50459)
197637 (A50459)
2000 Dnya RGN (A49461)
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A51039)
2003 International...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2012 Ford F-350 4WD Pickup Truck (A50860)
2012 Ford F-350...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
