Why Can't Someone Make a Good 12' Batwing Cutter?
   / Why Can't Someone Make a Good 12' Batwing Cutter? #21
I doubt there's a manufacturer in business with the nads to build a 12', 3PT batwing mower. That thing would be stupid heavy. I have a Maschio 10' flail that weighs 2100 pounds. I can't imagine picking anything much heavier up without front weights even with weights it would be uncomfortable.
   / Why Can't Someone Make a Good 12' Batwing Cutter? #22
Have you looked at the JD fc12e model?
Weighs 3580lbs , hows that compare to the one you have or others you’ve looked at? I don’t think any manufacturer builds a heavier duty mower in the 12’ foot class, if I was looking to buy it would be at top of my list
   / Why Can't Someone Make a Good 12' Batwing Cutter? #23
Had 2 Deere mowers for almost 20 years an neither gearbox has leaked when folded or in any position. Original, untouched gearboxes.
I change the gearbox oil every year and use only JD oil.
Been a great ownership experience. I highly suggest them. Excellent mowers that are tough and just about unbreakable.
   / Why Can't Someone Make a Good 12' Batwing Cutter? #24
Sounds like he wants the 12' JD mower in a 3PT model. He also wants it with hydro motors so he can lift each deck as needed. I'm waiting to see that.
   / Why Can't Someone Make a Good 12' Batwing Cutter? #25
I wouldn’t be surprised if there is one, but it would probably be an Italian mower of some kind.
What about a 15 footer that was factory changed to a 10 footer with on wing removed?
I know it’s 2 foot smaller than he wants, but it’ll be as heavy duty as they come.
Deere sells them that way.
Who are you referring to?
I don't want any 3pt mower at all.
But I do have separate hydraulic controls to operate the wings (both, not individually) and the deck height. My Woods 15' came that way, and I split off the wing/deck on my Viper myself.
Woods sells them that way too. But for the ranch pastures I cut with lots of trees, having only one wing would limit my turning direction to just one way while getting the wing under the canopy.
Saw that one online, and it looks pretty good.
   / Why Can't Someone Make a Good 12' Batwing Cutter? #29
My mistake. Another poster said that and I mistakenly thought it was you. Sorry.
   / Why Can't Someone Make a Good 12' Batwing Cutter? #30
2000 Big Tex 22GN-24 Gooseneck Trailer (A59213)
2000 Big Tex...
BUNDLE OF ANCHOR ROPE (A58376)
BUNDLE OF ANCHOR...
6' BROWN TREE CUTTER (A58375)
6' BROWN TREE...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
5ft Bench Seat (A57454)
5ft Bench Seat...
Unused 20x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 20x20...
