Why Are There Two ON Positions on New Holland Fuel Strainer Bowl?
   / Why Are There Two ON Positions on New Holland Fuel Strainer Bowl? #21
You definitely know your stuff . It is the pleasantry of your delivery that makes your responds so soothing .
It's frustrating when folks take things they know about tractors they are familiar with and assume that tractors they have no experience with are built using the same ideas, sometimes 50 or 60 years later.
And it happens here all too often.
   / Why Are There Two ON Positions on New Holland Fuel Strainer Bowl? #22
Has anyone ever seen a diesel tractor with "reserve" fuel supply? I haven't, but that really doesn't say much. Reserve worked with the old gas engines but if a diesel runs out of fuel you're likely to have other things to take care of besides fetching a can of fuel.
   / Why Are There Two ON Positions on New Holland Fuel Strainer Bowl? #23
On a fuel tank with a reserve it would seem that if you hadn't used the reserve for several years the reserve pipe could get plugged up becasuse of no flow thru it. I think I remember this happening on the old Fords and Fergusons.
Being the reserve tap is the lowest in the tank, any rust or sediment will plug it first.
   / Why Are There Two ON Positions on New Holland Fuel Strainer Bowl? #24
It would interesting for someone to post the brands/models of diesel tractors with a built in fuel reserve if indeed there are such a tractor in existence!
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
John Deere 6ft (A56857)
John Deere 6ft...
Nugier H40-7 APBD H-Frame Shop Press (A59213)
Nugier H40-7 APBD...
Hydraulic rail grinder (A56435)
Hydraulic rail...
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
