who makes a 50+ pto HP with a hydrostat, no cab
   / who makes a 50+ pto HP with a hydrostat, no cab #1
searcyfarms
kingsville, mo
Farmall 560D - 706D German w/Cab - Volvo MC110 - 1944JD A - Deere 2038R - IH 5088
i think Kubota does.........friend is looking for one and i looked at Mahindra site, nothing there - he wants hydro for his wife - and the tractor large enough to hand a BIG round bale of hay
i didn't see anything on LS either - they go to power shift when u get into that much hp it looks like
others ?
   / who makes a 50+ pto HP with a hydrostat, no cab #2
I thought all the brands did?? Kubota does, I like the MX line, due to cost. Lol
Massey does, the 2706e can be had with hydro, and is over 50hp. I'm sure the other brands have them as well
   / who makes a 50+ pto HP with a hydrostat, no cab #3
The Kubota MX5800 gets you to 50 HP...barely. I've got one but I think you'd be putting a lot of stress on it to round bale with it. Not sure if you can get the 6060 or 7060 with HST but I know you can get them cab-less.
I have never bailed but researching about it, it doesn't look like something I'd enjoy without a cab:stirthepot:
50+ or even 55+ seem hard to come by when you are talking PTO, he is not going to be haying per say with it but wanted to be able to lift a big bale if needed to and i told him it will definitely have to have a ballast, these newer tractors are sooooo light, even these 55hp are only not even 4000 lbs - were talking less than a 65 massey or far less than a d17 or even a 400 farmall/560 is getting close to 7000lbs - i wouldn't put my wife on a 4000lb tractor and tell her to pick up a big bale of hay unless i didn't like my wife lol - thats dangerous - id want another bale on the back for ballast but putting that kind of weight on a 4000lb tractor i think would be too much especially if you were on rough ground might not be good for tractor?
goose - the 2706E is only 45.9 pto so far short of 55 pto, im barely finding 50pto on the hydros and less than 4000lbs on two of the 3 i found
   / who makes a 50+ pto HP with a hydrostat, no cab #6
I have looked at Deere, Kioti, and LS, all have 50+ hp in hydro.
   / who makes a 50+ pto HP with a hydrostat, no cab #7
ok that is what i was seeing too just thot i might be missing something - i see a couple just about 50 or just over but nothing over 55 PTO - and weight still no more than 4000 - i think he is going to need to go to syncro shuttle
   / who makes a 50+ pto HP with a hydrostat, no cab #9
others ?
Maybe I read it to hastily, they're trying to bale with this tractor or move bales? If they are just trying to move bales around the MX is probably perfect.
   / who makes a 50+ pto HP with a hydrostat, no cab #10
I have a JD 4720 HST with cab that is rated at 56hp PTO.
dsb
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
New Holland B95 Backhoe (A50490)
New Holland B95...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
