who makes a 50+ pto HP with a hydrostat, no cab
   / who makes a 50+ pto HP with a hydrostat, no cab #1
searcyfarms
kingsville, mo
Farmall 560D - 706D German w/Cab - Volvo MC110 - 1944JD A - Deere 2038R - IH 5088
i think Kubota does.........friend is looking for one and i looked at Mahindra site, nothing there - he wants hydro for his wife - and the tractor large enough to hand a BIG round bale of hay
i didn't see anything on LS either - they go to power shift when u get into that much hp it looks like
others ?
   / who makes a 50+ pto HP with a hydrostat, no cab #2
I thought all the brands did?? Kubota does, I like the MX line, due to cost. Lol
Massey does, the 2706e can be had with hydro, and is over 50hp. I'm sure the other brands have them as well
   / who makes a 50+ pto HP with a hydrostat, no cab #3
The Kubota MX5800 gets you to 50 HP...barely. I've got one but I think you'd be putting a lot of stress on it to round bale with it. Not sure if you can get the 6060 or 7060 with HST but I know you can get them cab-less.
I have never bailed but researching about it, it doesn't look like something I'd enjoy without a cab:stirthepot:
50+ or even 55+ seem hard to come by when you are talking PTO, he is not going to be haying per say with it but wanted to be able to lift a big bale if needed to and i told him it will definitely have to have a ballast, these newer tractors are sooooo light, even these 55hp are only not even 4000 lbs - were talking less than a 65 massey or far less than a d17 or even a 400 farmall/560 is getting close to 7000lbs - i wouldn't put my wife on a 4000lb tractor and tell her to pick up a big bale of hay unless i didn't like my wife lol - thats dangerous - id want another bale on the back for ballast but putting that kind of weight on a 4000lb tractor i think would be too much especially if you were on rough ground might not be good for tractor?
goose - the 2706E is only 45.9 pto so far short of 55 pto, im barely finding 50pto on the hydros and less than 4000lbs on two of the 3 i found
   / who makes a 50+ pto HP with a hydrostat, no cab #6
I have looked at Deere, Kioti, and LS, all have 50+ hp in hydro.
   / who makes a 50+ pto HP with a hydrostat, no cab #7
ok that is what i was seeing too just thot i might be missing something - i see a couple just about 50 or just over but nothing over 55 PTO - and weight still no more than 4000 - i think he is going to need to go to syncro shuttle
   / who makes a 50+ pto HP with a hydrostat, no cab #9
others ?
Maybe I read it to hastily, they're trying to bale with this tractor or move bales? If they are just trying to move bales around the MX is probably perfect.
   / who makes a 50+ pto HP with a hydrostat, no cab #10
I have a JD 4720 HST with cab that is rated at 56hp PTO.
dsb
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
