Which quick attach for a Kubota B3300SU?
   / Which quick attach for a Kubota B3300SU? #1
neumanda
Mattawan, MI
Kubota B3300 SU
Hey TBN folks,
I have a Kubota B3300 SU with a 5ft brush hog and a back blade. Putting the brush hog on and off is a heroic job for me at the moment. The back blade is a little better because it is lighter. I have no real help when putting these implements on and the last time I put the hog on I was seriously concerned about intracranial hemorrhage because of the effort. As soon as I can I plan on purchasing a tiller which will be another heavy piece.
I bought a used quick attach off craigslist, but it didn't fit any of my implements and I couldn't get it to fit properly on my tractor. I've been reading about other quick attaches as well. Unlike JD, Kubota does not have a quick attach they market. So my question is what is a quick attach that will function with my equipment? Any of you Kubota owners have a solution to my problem?
Thanks in advance.
Dave
   / Which quick attach for a Kubota B3300SU? #2
Do you mean a Quick Hitch?
   / Which quick attach for a Kubota B3300SU? #3
I assume he meant a quick hitch. If not, let us differentiate for him. Quick hitch is for the rear/3 point implements. Quick attach is generally a skid steer type system for implements attached to the front loader arms.
When I had a B3030 I had a Speeco quick hitch from Tractor Supply. Sometimes took some adjusting of the top link, moving of pins, etc. when changing from implement to implement. Once you find a hitch that's suitable for you, I'd suggest that when you drop an attachment you let it down onto some sort of dolly. Much easier to roll your attachment around by hand to mate to your hitch if necessary.
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
ExMark Quest Zero Turn Mower (A50860)
ExMark Quest Zero...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2019 John Deere 333G Skid Steer (A50657)
2019 John Deere...
Iron Cabinet (A50860)
