Where do you get little pucks or skis to keep snow blade from biting gravel drive?
   / Where do you get little pucks or skis to keep snow blade from biting gravel drive? #21
How are the edge tamers on concrete when removing snow? Do they mark/scratch it up?
   / Where do you get little pucks or skis to keep snow blade from biting gravel drive? #22
Interesting discussion, specially the edge tamers on the bucket. I plowed last year with the bucket in float position, my first tractor plowing experience. I can see how the edge tamers would have helped.
I just picked up my ssqa plow project, an older manual adjustment kwik-plow mounted to a ssqa bracket, custom welded by a friend. It’s a bit heavy for my Kioti CK2510, I’m worried about digging up the dirt or damaging the asphalt. The Fisher plow shoes are 1-1/4” diameter rods on the round bases, the Kwik-plow brackets are 1” diameter. I found Western plow shoes at Tractor Supply with the 1” diameter rods on cast round bases, that fit nicely. I’ll get a chance to try them out tomorrow after this latest snow storm is done.
   / Where do you get little pucks or skis to keep snow blade from biting gravel drive? #23
You could slot a length a pipe to fit over the entire edge of your bucket. The curve of the pipe will keep it from digging into the gravel. I did this on my 8' Fisher plow that's on my tractor and it works great. I don't have any pics of it to post here at the moment but can upload them in a couple days.
Found this one here though....you do it kinda like this....
https://www.tractorbynet.com/forums/snow-removal/404098-just-bought-tractor-summer-no.html
2005 John Deere 200C LC Excavator (A59213)
2005 John Deere...
2012 HEIL (A58214)
2012 HEIL (A58214)
Kubota L4060HSTC 4WD 42HP Utility Tractor NR (A56857)
Kubota L4060HSTC...
Magnum 4000 Series Hot Water Pressure Washer (A55272)
Magnum 4000 Series...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
