What strange things have you moved with your loader..pics
   / What strange things have you moved with your loader..pics #271
I know this is a FEL thread and not for 3PH, but my story sort of fits here. I lifted and pulled out a column footing from under my house with the 3PH on my little Kubota BX. I welded a couple chain hooks onto a steel plate which was then bolted to the footing with a couple expanding anchors. It lifted it with not problem.:thumbsup:
I had to temporarily unbolt my ROPS since it was hitting my HVAC unit. With that in mind I made sure to only lift the footing up an inch or so above the ground.
   / What strange things have you moved with your loader..pics #272
Not real heavy, only a little over 200# each, Just wanted to get the stoves up off the ground and on a little table.
Grader tire was picked up and carried a little over a mile. Not sure how heavy it is, but it stretched the links on my 1/4" chain a little. Center of wheel is cast iron, tire 14X24 and may have water in it as most of his other tires do.
   / What strange things have you moved with your loader..pics #273
i dont know if this counts but i helped my granddad lift the cab off of a 50s era strait truck with his 75hp jd. and let me tell you there was alot of steel in that. had to put a drive gear on the blade from a 6620 jd combine to keep fom putting it on its nose
   / What strange things have you moved with your loader..pics #274
Here you all go - beat this one.
A hot tub!
   / What strange things have you moved with your loader..pics #275
What do you hook the other end of a come-along to in a house!!?!?!?! :confused3:
I used a San Angelo Bar between two doorways in the hall. I had virtually the same experience with a new gun safe. :)
For those who don't know what that is
   / What strange things have you moved with your loader..pics #276
Last year I purchased an automotive lift to help in my car restoration hobby and to allow me to service my Mahindra 5035. I saved the off load fee and picked up the pallet off of the rear of a box truck. I weighed 2950 lbs. My loader is rated for 3000lbs i believe. i have a very steep driveway and at the time, there was no ballast in the rear tires, but my 5035 handled it with no issues. I was too anxious to take pics during the move of the full pallet, but I do have few pics of my moving the pieces from a detached garage to my project garage. I will find them and add them asap.
Merry Christmas All!
   / What strange things have you moved with your loader..pics #277
starting the transfer 1.jpgside shot.jpgfrom old garage to new.jpgmore to do.jpgHere are the pics. Sorry for the delay. Busy time of year, eh?
I guess it wasn't really that strange to the tractor community, but it was a big deal to me at the time. Such a helpful tool, my 5035. What did I do without her all of these years??
   / What strange things have you moved with your loader..pics #278
No pics, but I moved a whole bucket of osage oranges the other day. It's too bad my other fruit trees aren't as productive as that osage orange tree is!
   / What strange things have you moved with your loader..pics #279
No pics here either, but I loaded a few 10x10 wooden shipping containers onto a trailer for a friend. He was going to take them to his deer lease, put them together and build a makeshift building out of them. He said it'd be at least 100% better than the trailer he'd been using for years. Talk about your redneck condo! :laughing::cool2:
   / What strange things have you moved with your loader..pics #280
Moved some speakers around so we could do an outdoor movie. Was a big success.
Not sure if the pictures will work....first time I've ever attached pictures using this (new to me) method.
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2021 CTS HRD 37LW 34 Ton T/A End Dump Trailer (A55973)
2021 CTS HRD 37LW...
550 GALLON FLAT BOTTOM POLY TANK (A58374)
550 GALLON FLAT...
2007 JLG 450AJ SERIES II SKYPOWER BOOM LIFT (A52709)
2007 JLG 450AJ...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
