What size bolt on L4400...Help please
   / What size bolt on L4400...Help please
simonmeridew said:
Hi city:
On my L4400 I just tried sockets on all the hydraulic bolts I could find. Some were 23 mm and others were 26 mm. Most were 26mm.
simonmeridew
Thanks for this.
I actually do have a fairly comprehensive set of sockets and spanners both metric and imperial. My problem is that they were all too small. I tried a 12" adjustable but it would not get onto the bolt properly.
Thanks Alchemysa I will check it out and can then leave the set on the farm rather than drag my good ones back and forth.
Cityfarma
   / What size bolt on L4400...Help please #12
Yeah they look bigger sized, 22, 24, 26 range.
Owning a tractor requires a 15" cresent. Nothing wrong with a cresent on a larger nut.
Rob
   / What size bolt on L4400...Help please #13
Hi again City:
OK I went back out to the barn now that it's light out and put a 26mm socket on the bolt that you talked about, attaches the U shaped hydraulic pipe to the block. Perfect fit. So that's the the size: 26 mm.
simonmeridew
simonmeridew said:
Hi again City:
simonmeridew
Thanks Simon. A 26mm spanner is now on my shoppng list. Also thanks to others for taking time to respond.
Cityfarma
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
UNUSED FUTURE KH72 72" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE KH72...
UNUSED JCT 72" HYD BRUSH CUTTER (A57193)
UNUSED JCT 72" HYD...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2018 Lexus IS300 Sedan (A55853)
2018 Lexus IS300...
