What size bolt on L4400...Help please
   / What size bolt on L4400...Help please
simonmeridew said:
Hi city:
On my L4400 I just tried sockets on all the hydraulic bolts I could find. Some were 23 mm and others were 26 mm. Most were 26mm.
simonmeridew
Thanks for this.
I actually do have a fairly comprehensive set of sockets and spanners both metric and imperial. My problem is that they were all too small. I tried a 12" adjustable but it would not get onto the bolt properly.
Thanks Alchemysa I will check it out and can then leave the set on the farm rather than drag my good ones back and forth.
Cityfarma
   / What size bolt on L4400...Help please #12
Yeah they look bigger sized, 22, 24, 26 range.
Owning a tractor requires a 15" cresent. Nothing wrong with a cresent on a larger nut.
Rob
   / What size bolt on L4400...Help please #13
Hi again City:
OK I went back out to the barn now that it's light out and put a 26mm socket on the bolt that you talked about, attaches the U shaped hydraulic pipe to the block. Perfect fit. So that's the the size: 26 mm.
simonmeridew
simonmeridew said:
Hi again City:
simonmeridew
Thanks Simon. A 26mm spanner is now on my shoppng list. Also thanks to others for taking time to respond.
Cityfarma
UNUSED FUTURE RB66-66" ROCK BUCKET (A57193)
UNUSED FUTURE...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
American G-Model Pump Jack (A55315)
American G-Model...
16' L X 3 1/2' W X 6 1/2 H HEAVY DUTY STORAGE RACK (A57192)
16' L X 3 1/2' W X...
2007 Ford E350 (A55973)
2007 Ford E350...
LaneShark LS3 (A56469)
