Oil & Fuel What is this?
   / What is this?
And my 4600SU
   / What is this? #22
Besides buying a new fuel tank, if it is rusty inside the tank you can drain it, clean it and put some fuel resistant epoxy in it.
   / What is this?
I was just curious if I keep the tank full from here on out will it stop the rust process? I know the rust will still be in there but if it no longer causes any issues then I would be OK with it.
   / What is this? #24
Once you have corrosion, it probably will continue to some extent, unless you treat it.
   / What is this?
Yeah your probably right. I'm going to try it though and if it doesn't work I'm just getting a new tank. Found out there not that expensive so much less headache.
   / What is this? #26
I have seen perfectly clean steel tanks,,, with a rusted cap.
You need to do some looking.
   / What is this? #27
I too have rust on my fuel cap, never thought it might be bacteria. I believe I'll scrape a little off and see if it sticks to a magnet.
   / What is this? #28
Rust is converted iron,, many times it is non-magnetic. In some cases, it is partially magnetic.
   / What is this? #29
Why wouldn't the scrapings be magnetic? It's steel.
It could be rusting from condensation too.
Bacteria is what they say is eating the titanic though.
   / What is this? #30
CAD and Ray,
If I get around to doing the magnet test I'll post the result. I'm guessing a magnet would attract partially magnetic rust and not bacteria. If it's totally non-magnetic rust I'm still in the dark.
UNUSED FUTURE CAT 305 44" EXCAVATOR RAKE (A57193)
UNUSED FUTURE CAT...
UNUSED 1RGC40 MINI GOLF CART (A57193)
UNUSED 1RGC40 MINI...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
UNUSED FUTURE 1 SHANK RIPPER (A57193)
UNUSED FUTURE 1...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
