Oil & Fuel What is this?
   / What is this?
And my 4600SU
   / What is this? #22
Besides buying a new fuel tank, if it is rusty inside the tank you can drain it, clean it and put some fuel resistant epoxy in it.
   / What is this?
I was just curious if I keep the tank full from here on out will it stop the rust process? I know the rust will still be in there but if it no longer causes any issues then I would be OK with it.
   / What is this? #24
Once you have corrosion, it probably will continue to some extent, unless you treat it.
   / What is this?
Yeah your probably right. I'm going to try it though and if it doesn't work I'm just getting a new tank. Found out there not that expensive so much less headache.
   / What is this? #26
I have seen perfectly clean steel tanks,,, with a rusted cap.
You need to do some looking.
   / What is this? #27
I too have rust on my fuel cap, never thought it might be bacteria. I believe I'll scrape a little off and see if it sticks to a magnet.
   / What is this? #28
Rust is converted iron,, many times it is non-magnetic. In some cases, it is partially magnetic.
   / What is this? #29
Why wouldn't the scrapings be magnetic? It's steel.
It could be rusting from condensation too.
Bacteria is what they say is eating the titanic though.
   / What is this? #30
CAD and Ray,
If I get around to doing the magnet test I'll post the result. I'm guessing a magnet would attract partially magnetic rust and not bacteria. If it's totally non-magnetic rust I'm still in the dark.
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
UNUSED SDLANCH SDLD 25 HYD DUMP BUGGY (A57192)
UNUSED SDLANCH...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
WHIRLPOOL REFRIGERATOR (A57192)
WHIRLPOOL...
