What is the best way to install a grab link onto a chain?
   / What is the best way to install a grab link onto a chain?
hslogger,
I was planning to use the choker end to pick up the end of a log for dragging and also to lift rocks and place them while landscaping.
Are either of these applications okay to use the keyhole assembly?
[video]https://goo.gl/images/AEa1rn[/video]
Egon, this may be the best way and easy on and off. I see if it works later today.
   / What is the best way to install a grab link onto a chain? #14
hslogger,
Depends on how configured.
Keyhole is for "grabbing" a chain. It's convenience is it doesn't have to grab the end of the chain. You can pull through the slack and grab.
You want the end of the choker that's around the log to slip where it loops back onto itself so that tension tightens and makes a good grip on what is being pulled (log, etc..), and releases tension so you can unhook it when not pulling.
The other free end of your choker chain typically gets grabbed by whatever pulls it (cable, chain, notched bar/keyhole, etc..).
Typically people use "keyhole sliders" on the "pulling cable/chain". That is, the keyhole, or grab hook isn't on the choker chain, it's on what grabs the choker chain.
Another way: You don't need to "install" your grab link on any chain. Grab it with a link on the end of your choker chain. Loop choker around log (etc.) then slide other free end of choker chain through (slip part of) link (now log is looped), then grab free end of choker chain with a grab hook (or keyhole slider, etc...) that's on your main pull cable, chain, etc...
   / What is the best way to install a grab link onto a chain? #15
hslogger,
I wouldn't use it for elevation situation where it is up in the air, because while effective and strong IMHO these aren't accident proof in "flying it around". Trying to wrap anything but say nylon or hemp rope around odd shaping boulders can be daunting.
One of the TBN contributors made a video about the grab hook on one end, and a steel rod mounted on the opposite end of his chain.
He showed how he uses both ends. think he was from N. Carolina?
Not sure how to find the video, but would help to demonstrate how I would like to use this.
   / What is the best way to install a grab link onto a chain? #17
The rod end is the same, but on the opposite end I remember him using the keyhole as both a grab and slip by flipping it around. Good if we could find the video.
Tools & equipment for small scale logging - YouTube
Found it. In the beginning of the video he shows how he uses both ends of the keyhole link.
His is fixed right into the chain. My issue is that the keyhole link I purchased is for 3/8" chain (only size I could find)
and it's going onto a 5/16" chain. And I would like to be able to easily mount it and remove it.
Need a way to get it on and off the chain and have it able to rotate for varied use.
   / What is the best way to install a grab link onto a chain? #20
In the years before I entered the world of tractors, back in our poor but energetic youth,
my wife and I hauled the logs for our soon to be log home using a gas motored ,self propelled logging winch mounted on a skid.
We put one of these links on a swivel that was attached to the winch cable and hooked the chain chokers to it.
The design allows you to easily choke or release the chain just by flipping the link. Very handy unit.
2001 Chevrolet C6500 Wrecker Tow Truck (A55852)
2001 Chevrolet...
Moffett M5000 Truck Mounted Forklift - 5000 lbs Capacity - Side Shift (A55315)
Moffett M5000...
UNUSED SPLANCH SDLD25 DUMP BUGGY (A57192)
UNUSED SPLANCH...
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A57193)
UNUSED FUTURE...
2003 Big Tex 10PI...
John Deere Quick Hitch (A53317)
John Deere Quick...
