What engine oil are you using in your Branson?
   / What engine oil are you using in your Branson? #11
I want to use Rotella T6 15W40 in the 4815C. I have always had good luck with Rotella and think I will use full synthetic for the life of this tractor.
In an effort to keep things simple, I am converting the Kioti to the fluids I will use in the Branson.
The problem I have is I was only able to find 1 gallon of the T6 15W40 in the big city of Mineola TX. Plenty of the 5W40 but the manual is calling for the 15W40. If I was in a cooler climate, I would be fine with 5w40 but think I should stick with what Branson says to use.
The Kioti engine has had Rotella T4 15W40 from day one. What would you use?
Your manual is WAY out of date. VW has used 5w30 in its diesel engines since WAAAAY back. That's what I now have in both the 2025R and Isuzu generator. Gives WAAAAY more protection to the upper valve train on startup than any 15wxx oil will. My VW Cabrio had a hydraulic valve with draindown problem. It would hammer away for 2 or more seconds at startup unless I used 0w30 in it. This is what I plan to do for the next oil change. You can often find 0w30 ESP M1 (diesel oil) on Amazon for less than $9/qt I've been paying VW for the Castrol.
Ralph
   / What engine oil are you using in your Branson? #12
My dealer put in Amsoil synthetic 15w40 at my 50 hr. I'm coming up on my 300 hr soon and will try to replace with same. I require my tractor to operate routinely in temps from -40F in winter to +95 F in summer.
   / What engine oil are you using in your Branson? #13
If your outside at -40f good luck to you.....I will be looking out the window........:)
   / What engine oil are you using in your Branson? #14
Lol.
That's why I insisted on a cabbed tractor.
Around here, -40 F is just called "Tuesday" (Well, in winter anyway).
I sure would never want to tangle with Slim! He is much a man to be able survive in that climate!!:eek:
   / What engine oil are you using in your Branson? #16
Lol. No, a "Real Man" wouldn't want a cabbed tractor.
Don't you read the forums?
:laughing:
   / What engine oil are you using in your Branson? #17
I worked in the oil basestock industry for 31 years. During that, we were privy to and worked closely with our Canadian research arm in Sarnia, Ontario. At one point, they put a Dodge 024 four cylinder in a -40 room overnight and tried restarting the next morning with various oils. They had a transparent valve cover on it. EVERY oil but a 0wxx one smoked the valve cover underneath quite significantly. The oil pumps just would not pick up the oil unless it was 0wxx until the pump sat there and warmed up the oil a bit first. In the meantime, the engine was running, and the valve train was getting NO lubrication. The only oil at that time that could be had in 0wxx form was Mobil 1. We could not make a dino oil to 0wxx specs and still meet the Noack volatility spec. Just not possible.
Finally, after retiring and merging with Mobil, I could use Mobil 1 with a good conscience. Been using it ever since. A 0w30 was the ONLY oil in a VW Cabrio that would refill a leak-downed hydraulic valve lifter and not let it hammer away for a couple seconds, even in the summer. 0w20 is all I use in my 3 gasoline engines. I'd been using 5w30 Castrol LL03 in my 2 diesel engines (as I had for 7 years in our VW TDI) but have run out of it (from what I bought with VW $). In future, think I'll order 0w30 ESP M1 online. Have found it on Amazon for less than the $9/qt that VW charged me last time.
Ralph
   / What engine oil are you using in your Branson? #18
I think too much is made over this brand versus that brand of oil. As long as it meets specs and is in the proper viscosity range, it is adequate. This brand being better than that brand is usually not based on anything factual. Most failures reported to be related to engine oil are usually caused by another problem, but blamed on the oil as it is an easy target.
   / What engine oil are you using in your Branson? #19
I was in the Air Force based in Glasgow, Montana during the winter of 1966 and got to experience some of Slim's weather (-40 without a chill factor applied, and a very strong wind). Unfortunately I worked outside on the flight line, and not at a desk job. We used UPS style step vans for work stations that had been modified to have their radiators mounted in the open directly behind the driver for more effective cabin heating. You would go out and work on the aircraft for a couple minutes and go back inside the truck to warm up. One night a crew forgot to park one of the trucks inside the hanger. The engine wouldn't even turn over the next morning. We decided to push start it with an aircraft tow tug. The truck was so cold that the grease in the wheel bearings and/or differential had solidified, and the wheels just slid along the ground without turning!
Slim, it takes a man to live in that climate, even with a cab.
   / What engine oil are you using in your Branson? #20
I use an oil pan sump heater (stick on pad) and a hydro sump heater (also a stick on pad) along with a standard block heater in my tractor. I have them all 3 plugged into a single pigtail that's zip tied to a loader arm. I plug in my tractor via a programmable timer to come on at 5am, and turn off at 9-10am (can't remember on the "off" time). I leave it plugged in all winter long, and usually, if I need it for pushing snow, it will likely be first thing in the morning anyway. However there have been a few times I've had to plow the driveway again when I get home at night, so I unplug the cord coming out of the timer, and plug it directly into the outlet above for an hour or so.
Neither one of our vehicles gets plugged in, ever. Both are gas engined, and both start without issues even down at -40 F and a bit colder.
On our vehicles, Mrs. Slim's '07 4 Runner is running a straight synthetic oil, of a weight I couldn't tell you off hand. The Toyota dealer in town does it, and they put in whatever weight synthetic called out by Toyota. On my '12 Superduty, I'm still letting the Ford dealer do my oil changes for free (from original purchase), and they're putting in a "synthetic blend" oil which is (I believe) 5w-30. I still have one more free oil change from my dealer, and after that, if wherever we move to I actually have a HEATED shop, I may start doing them all myself (I know how, I'm just old, fat, and lazy).
:laughing:
2013 John Deere 650K Crawler Tractor Dozer (A56857)
2013 John Deere...
E-Z-Go Workhorse Electric Utility Cart (A55851)
E-Z-Go Workhorse...
DEUTZ MARATHON...
2012 New Holland BR7070 Round Baler with XtraSweep and Net Wrap (A57024)
2012 New Holland...
2014 John Deere 204K Wheel Loader (A53485)
2014 John Deere...
2007 Sterling Acterra S/A Dump Truck (A55852)
2007 Sterling...
