What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #361
   / What else do you do with forks besides lift pallets? #362
Great! 1" hole should be large enough for a slip hook, I would think?
One inch would definitely accommodate a shackle pin or a trailer hitch ball.
   / What else do you do with forks besides lift pallets? #363
Thanks again. I forgot how handy a trailer ball could be.
I bought heavy duty 4' forks and I wish they would have come with holes in the ends for chain hooks. Not sure how hard they will be to drill. I would imagine they are hardened steel.
They are really easy to drill.
Drilling is the only way to go. A torched hole always looks bad.
   / What else do you do with forks besides lift pallets? #365
I needed a hole in a fork tip, used a hole saw in the drill press. Easy cutting and a nice clean hole.
   / What else do you do with forks besides lift pallets? #366
Wow! You must have a lot better hole saws than I do. Mine barely cut wood.
   / What else do you do with forks besides lift pallets? #367
Try an annular cutter in a drill press at a proper speed and some good quality cutting oil like Tap Magic. Should be a piece of cake.
   / What else do you do with forks besides lift pallets? #368
I just looked, it's a Rigid 1", nothing special. I'd have taken a pic except my tablet won't hold a charge anymore and is dead and my camera don't like any of the AA batteries in the house. Ain't tech wonderful.
   / What else do you do with forks besides lift pallets? #369
That was certainly enlightening. Never heard of annular cutters before and now I am intrigued.
   / What else do you do with forks besides lift pallets? #370
I built a box that I can safely stand in and cut branches while somebody drives the loader tractor. We push brush and logs all the time. Torched a hole in each fork so we can pull/push equipment around with them.
2005 Winnebago Sightseer 30B 30ft. Class A Motorhome (A55853)
2005 Winnebago...
2008 Ford F-350 Pickup Truck (A55852)
2008 Ford F-350...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
(10) 24' CORRAL PANELS W/ (1) 8' GATE (A57192)
(10) 24' CORRAL...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
Blue Diamond 103709 (A53317)
Blue Diamond...
