What do you use in your GDI engine to clean the intake valves?
   / What do you use in your GDI engine to clean the intake valves? #1
5030
Epic Contributor
SE Michigan in the middle of nowhere
Kubota M9000 HDCC3 M9000 HDC
Been using Seafoam GDI top end engine cleaner right along but I see there are others out there like CRC for instance. The issue with the newer GDI (gasoline direct injection) engines is, the intake tract is basically devoid of and gasoline (dry), so the intake valves receive no detergent in gasoline) cleaning as you drive and they carbon up and it eventually causes engine driveability issues and decreased performance.
I use the Seafoam GDI engine cleaner every oil, change. Keeps everything tidy and clean inside, at least I think it does. All I know is, the engines purr and the fuel mileage is excellent.
What, if anything do you guys use?
2007 Ford F750 (A55973)
2007 Ford F750...
2016 Ford F-150 4x4 Pickup Truck (A55852)
2016 Ford F-150...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
