What do you like least about your tractor?
   / What do you like least about your tractor? #21
Well I've got a 4310hst as well, only have about sixty hours on it so far. Of coures there is a few add ons that need to be done but, here are a few of the things that I dont like. Hummm or am I only allowed one? Oh well here goes
1. Sidelink adjustment setup--With a hydraulic toplink and while raising or lowering the sidelink there is VERY LITTLE clearance between the handle of the sidelink and the hydraulic toplink. If your not careful, squished fingers.
-----Fix-----hydraulic sidelink!!!!
2. Lift capacity of the loader. --loader needs more spunk.
3. Front heavy duty grille guard is a joke.---needs expanded metal put on to keep limbs from doing damage. I should say it works great if you would run into the side of a dumptruck and that is what it's designed for.
I still at times reach for a lever that just isn't there anymore./w3tcompact/icons/smile.gif
Gordon
   / What do you like least about your tractor? #22
Couple things on the L4610...1.The toolbox that is not much more than a pencil holder and I have not needed a pencil while tractoring. 2.The way the ROPS is designed and built so it can't be removed easily.(I'm dodgin' apple showers when I mow). 3.A mid PTO should be standard equipment on the larger L series Kubotas. 4.The cupholder from another post/w3tcompact/icons/wink.gif.Other than that, she's an awesome tractor/w3tcompact/icons/smile.gif
regards
Mutt
   / What do you like least about your tractor? #23
L4610HSTC
1. Really really really miss not being able to put a Kubota back hoe on it.
2. Really mis not being able to find a decent after market backhoe for it.
3. Amen to MUTT regarding missing cup holder and the cute little nearly useless pencilbox/toolbox.
(Let us know what you do regarding an external toolbox.) I actually hadn't thought about pencils yet, I hadn't come up with any use for it except a place to put the PTO dustcover and maybe a spare hair pin or hitch pin.
4. I really don't like the hobbyhorsing (bobbing up and down front to back kinda motion) which is induced by suspension geometry, short wheel base and adding front wheel drive. When in 4wd and with the steering full or near full to one side or other, any throttle above idle induces bothersome oscillations.
5. Sometimes requires extraordinary procedures to shift gear ranges (HST). It isn't enough to set throttel to minimum, come to a full stop, depress the clutch, and shift ranges. You have to sometimes let the clutch out and rock the HST pedal fore and aft while gently keeping force on the shift lever to get it in gear (usually works). Sometmes more manipulations are required.
6. Shifting into and out of 4wd is as in (5) above but happens more often and the extra measures work less often and with more difficulty. Lately I've taken to pulling ahead or back very very slowly while trying to put it into or out of 4wd. Works more often.
7. Although really quiet at idle and just above, at PTO speed or anywhere close the cab is a very noisy environment requiring hearing protection that makes a radio (comes with provision for radio and stereo spkrs) a mute issue, or should that be a deaf issue?
8. When the heat index got over 110 the A/C was barely able to cope or not depending on how vigorous I was in the cab duties, working the controlls. It may have been OK for brush hogging in open territory but doing FEL work exercises the operator a lot more. Still, compared to the outside environment it was a huge amount better.
Still I really like this tractor, my first. (75 hrs)
Paltrick
   / What do you like least about your tractor? #24
I use a really stiff spring to keep enough tension that it doesn't rattle except at PTO speeds...and above 2200RPM I use hearing protection anyway.
Pete
www.GatewayToVermont.com
   / What do you like least about your tractor? #25
I also don't like the flimsy plastic, the R4 tires I hate, the seat on the backhoe is really uncomfortable, should come with a rear light, and the fact that my dang gas gauge is broke and I didn't know it and it left me way out in the field when the tank said a quarter and she was bone dry!!
   / What do you like least about your tractor? #26
Ditto on the missing cup holder and microsized tool box. My list adds the lack of FEL bucket level indicator and also I'm not fond of the exhaust being lower and in front of my big nose. The heat and smell of diesel exhaust on 90+ degree bush hog days can get to you if you can't have a cold beverage in your (missing) cup holder!
   / What do you like least about your tractor? #27
IndianaPaul,
The lack of engine compartment panels is one of the reasons I went with a JD4700. That was semi big deal for me since I'm pushing brush all the time. The TC45 sorely tempted me in my purchase decision....
On the 4700 the only thing that comes to mind that I bugs me is the engine noise especially at PTO speed. The RPMs for PTO operation are almost at the "red line" on the engine. I really wanted to move up to a 5000 series since their PTO RPM were much lower on the tach but there was no support for the JD48 at the time on the tractors.
Later...
Dan McCarty
   / What do you like least about your tractor? #28
CowBoyDoc,
I like the plastic fenders! /w3tcompact/icons/smile.gif But I forgot about that backhoe seat. I can't stand that they made it black instead of yellow. That black seat can heat up quickly in the sun! I compenstate by putting a towel on the seat to keep off the sun. That towel may make it a bit more comfortable as well.
Funny you should say something about the gas gauge. I had a problem with mine last year when it said I had a good quarter of a tank. I had just backed the tractor up to a monster pine stump put down the FEL when the engine sputtered and died. The truck was 3,000 feet away round trip and I made the trip a couple times before I got the engine started...... /w3tcompact/icons/frown.gif
BUT, the gage has been working ever since. I don't really get it except maybe it was hung up. I still don't trust that gage. When I'm getting low I start looking into the tank and sticking in a stick if I don't have any fuel to it top off. /w3tcompact/icons/smile.gif
Now that I think about it the JD manual while very good also leave out some important information. I never found in the manual how to start after running out of fuel. Pretty simple, just hold the key over until the engine catches and goes but it took a bit of time. The MX6 manual does not have a word I can find about how to maintain the slip clutch. Lots of legal beagel warnings though.... /w3tcompact/icons/frown.gif The manuals are very good they just leave out some information.
Later...
Dan
   / What do you like least about your tractor? #29
Mark,
Good topic! But do you really think that a True Blue Card Carrying member of "Club Blue" can find something wrong!
Well, I searched long and hard and the only thing that I can find that I don't like about the Mighty TC18 is that I can't find anything wrong with it! /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Actually, if I had it to do over again, the purchase that is, I would have waited and ordered the TC18 with power steering for an additional $600 at the time! I bought mine off the lot without power steering. It's fine for mowing and rotary cutting, but when I move dirt with the blade or rear scoop, I could really use the power steering.
JimBinMI
   / What do you like least about your tractor? #30
What I like least about my tractor is that it's still sitting on the dealer's lot 'cause I can't afford it right now./w3tcompact/icons/frown.gif Hope to change that in the spring, though! /w3tcompact/icons/smile.gif Sounds like Jonleonard and I have the same problem.
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
CEA 9' Rake (A57148)
12 X 20 CAR PORT (A58216)
12 X 20 CAR PORT...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2243 (A58376)
2243 (A58376)
2007 Chevrolet Silverado 1500 Pickup Truck (A56858)
2007 Chevrolet...
