what can i run with a power inverter?
   / what can i run with a power inverter? #11
Wow, didn't act like it posted the first one! LUTT
   / what can i run with a power inverter? #12
I have a 2000-4000 max inverter mounted in my GMC Z-71 It will run a 30 gal aircompressor with no problems I've used it to run 6 strands of construction lights at the new house and for my concrete mixer , When buying inverters buy the biggest load carrying model you can afford and it will last a long time .
   / what can i run with a power inverter? #13
The cheap inverters are a square wave output. Altho this is OK for univeral/brush motors, the semi synchronous induction type motors are very unhappy with this. I tried to run a 1/2 hp compressor with a 2KW cheap inverter. It would only start the compressor with the tank empty and would not build to cutoff pressure before it stalled. Be prepared for disappointment. ... A true sine wave inverter is another story. Quite a good power source actually. But costs 4x.
larry
   / what can i run with a power inverter? #14
Something I've noted that everyone has missed is the initial drain. It's a spike. Depending on the motor, like type, size, age and condition, it can spike the inverter anywhere from 2.5 times the normal draw upto 4 times the normal draw. In some cases, depending on what it is, it could be less (I'm used to using older/used equipment, so newer stuff likely operates better). Too many "severe" spikes can fry an inverter and even toast a genny.
   / what can i run with a power inverter? #15
I would be in the "probably work" or "might work" camp.. the load of that little harbor freight compressor is t312 watts.. but I bet the starting load is at least twice that. And I am not sure how the little motor on that compressor will like square wave. Please report back your findings. I am curious to know.
Wow lots of advice on this! Looks like I'm not the only one who has thought it would be handy!
   / what can i run with a power inverter? #17
I have a 2000 watt inverter in my work van, with 2/0 copper cables hooked to battery 3 feet away. WITH THE ENGINE RUNNING, i can run things like impact hammers, microwave oven, etc.
These take a huge draw on static battery. Also, most standard alternators cant keep up with their power draw. Be prepared to be left in the dark with a dead battery...dont ask me how i know this.
Personally, i use mine to keep all the cordless bats up to snuff and run the microwave. Occasional work light use also.
NEVER buy a cheap inverter. i did, and it caught on fire in a few months while running a 300 watt work light. If i handt had access to an extinguisher, id have lost my truck.
   / what can i run with a power inverter? #19
I had a gmc topkick, it had three heavy batteries and I had one 2000 watt inverted permanently setup. it worked really well for all my hand tools, drill motors , lights, etc. the starting capacitor from my compressor put such a strain on it that it finally burned out the inverter. I finally bought a 12volt quality air compressor and tank and mounted it under the hood. I am now buying a new LS 4047H tractor and will probably mount my air compressor and tank permanently on that. Bruce
Sounds like a interesting set up what kind is it and where did you get it?
UNUSED FUTURE (3) AUGER SET (A57193)
UNUSED FUTURE (3)...
2001 John Deere 4600 (A53317)
2001 John Deere...
(1) 10000 LB GEAR REDUCTION DROP LEG TRAILER JACK (A57192)
(1) 10000 LB GEAR...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
UNUSED FUTURE MISC HYD HOSE BUNDLE W/ FITTINGS (A57193)
UNUSED FUTURE MISC...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
