Welding advice
   / Welding advice #11
Harv,
I've always laughed at my wife for baking something in the oven for an hour and then grabbing the hot pan with bare hands. Right up to the time I finished welding a bracket, took off my glove and grabbed ahold of the blamed thing! /w3tcompact/icons/shocked.gif
They should be required to sell welders with a bucket of cold water! /w3tcompact/icons/wink.gif
SHF
   / Welding advice #12
hey hayden,
good choice going with a 110v mig. my first mig is a lincoln sp125 and mostly have run flux cored but have run solid with co2. hobart, miller and lincoln are all good machines. play around and you will find alot of different methods for different material thicknesses. preheat and the use of different gas mixtures can produce many diff. results. i myself, am not a welding expert. i have made and fixed a heck of alot of things using stick, mig and tig. materials i have welded are steel, stainless, aluminum and most recently zirconium. there are so many diff. parameters that it is mind boggling. the guys at weld supply houses can really help with all your diff. senarios. ya know, with 18 yrs of messing with it and all the stuff ive done, i would never say im a welder. a welder is like uncle george who was here at work when i started workin for my dad 20 yrs ago. he has welded just about everything there is to stick together. any weldable exotics, titanium zirconium etc. , the kind of guy that could weld perfect circles standing on his head! if you look closely, you will find older guys at weld suppliers that had 40 yrs of it and now are more like application enginneers that love to help. anyone can run a pass, but knowing the correct operating parameters is what makes the differnece. anyway, i went off on a tangent, good luck with yer new machine. the 110v mig machine, in my opinion is the most versitile, cheapest thing out there. ive fixed alot of stuff with my little lincoln at the tree nursery that hasnt broke with that. ya never know, in time you might, like me, go buy an engine driven welder and get the wire feeder for it. a year and a half ago i bought a new miller 225 bobcat and this winter bought the mig wire feeder for it. of course, the ole lady dont say much about tools since she can look outside and see the over 8000.00 worth of trees ive planted in exchange for welding repair at the nursery. have fun and avoid fumes.
rich
   / Welding advice #13
Hayden,
Just a thought, buy a good pair of gloves. (Expense is not optional). They'll save your fingers from a lot of scorching. And, pick up a better helmet than the one that probably came with your unit. You'll appreciate both.
SHF
   / Welding advice #14
Good gloves are great. Also make sure you have no exposed skin, it'l get sunburned real bad. I recommend the extra expense of an automatic darkening glass in your helmet. It makes things easier, a lot easier. You can see what you are doing with or without the arc going and never have to defy whiplash to "POP" your helment down while trying not to move the stinger...
Patrick
   / Welding advice #15
Another safety tip for newbie welders who smoke: Never have a plastic butane lighter (bic, et al) in your pocket while welding. There was a fatality in my area not too long ago: a lighter in a front shirt pocket exploded when a large molten glob hit it.
Matthew
   / Welding advice #16
Haven't used the auto helmets. I've always worried about trusting my eyes to someone else's electronics. What if the darned thing just doesn't work (batteries dead, caught a random surge from the welder, etc.)?
Anybody had any experience?
SHF
   / Welding advice #17
hey SHF,
i use the speed glass most of the time. havent had any problems at all except outside. i have to adjust the sensitivity knob a little. other than that it is great. it is good when you have to weld an area where you cant afford to miss yer mark. i have only had to put in a battery once in the last 3 years. you will know when it gives up. when i turn it on, i hold it up and look thru the lens and press the button and the lens changes. if not the battery is beat. ahh a little flash wont hurt, the lens is naturally darker anyway and it is alot better than a flash with no helmet. the worst thing other than welding with no helmet is an outsider working in the same area. they are the people who have the problems, even the reflection from the walls can mess up eyes. get one and change the battery every 6 months if yer concerned about it. there are times when i start to weld and the helmet isnt on. it has an auto shutoff and if im doin alot of grinding and it shuts off and i start a pass i know it isnt on. the flash doesnt even compare to when i weld and forget to put the helmet on. dont try that at home. no on the serious side, get one and you will be fine. i got hundreds of hours under the helmet and everythings fine. good luck. also it is the best thing for a beginner or rookie. i can remeber the days when id start welding a foot away from where i wanted to be. id flip the lid down and my welding hand would go with it.
rich
   / Welding advice #18
I don't have one of the auto helmets, but a buddy of mine does. He has well over 30 years of experienc with torch and spark. His is the latest design with the solar cell powering the darkening feature. (NO BATTERIES!) Also, the new ones lighten up much faster than the older ones.
His comment on using the helmet for the first time was "WOW!" Totally enjoys welding with it. If I had the $$$ I would get one too!
John Bud
   / Welding advice #19
If it runs on solar, can you weld inside with it? Or does it have some kind of back up system for working in a darker environment?
SHF
   / Welding advice
thanks for all the tips. I've got a pair of long cuff gloves from my gas welding days, and I bought a full face shield (the welder didn't come with anything). I'll wait on the auto dimming shields unless I find myself welding much more than I expect.
Thanks again,
Peter
2013 Ford Taurus SEL Sedan (A48082)
2013 Ford Taurus...
2014 Kia Soul SUV (A48082)
2014 Kia Soul SUV...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Fuel Tank (A50860)
Fuel Tank (A50860)
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
