welder opinion
   / welder opinion #1
arrow
Super Member
Foster, RI
Mahindra 3016
There has been much discussion on this forum about welders and such. As I have little experience with them, I'd lke to ask about a comparison that my limited experience has led me too. I have only welded AC stick. A tip from one of the posters (Highbeam?) stated that the 7014 was a sweet rod to use with ac. Well, he's right. It is much smoother than any of the other rods I've used (mostly 6011-6013) and I found 7014's also started better. My question, since never having welded with dc stick, how does the ac welder smoothness with 7014 rods, compare to dc welding with any other rods?
   / welder opinion #2
IMO, Not a huge difference between a good weld/bead with a AC compared to DC.
But that's the beauty of DC, smoother welds and easier arc starting with all the different rods.
I just stated using DC after 30 years of AC only, I wasn't blown away by DC with first use but am now appreciating it's subtle advantages.
I learned to deal with AC just fine, I think it would be more difficult going from DC to AC.
JB.
   / welder opinion #3
I think it is a marked difference between the 2 is that can produce a good quality weld with the AC but I really have to focus on what I am doing.With DC I can truly close my eyes and strike and hold an arc just by feel and sound. I weld with my eyes closed though.:D But if you are going to buy a stick welder do yourself a big favor and get a AC/DC you will be glad you did. the other thing a DC can do is weld aluminum with stick.
   / welder opinion #4
you get more rod choice with dc.. also gets you better in OOP for some rods.
soundguy
   / welder opinion #6
out of position
soundguy
   / welder opinion #8
Once you get the hang of not standing under the puddle, and putting on those shoe covers, it becomes less painfull....:rolleyes:
   / welder opinion #9
And don't forget to un-tuck your shirt so the sparks don't drop into your belt line and start your belly on fire. (don't ask how I know that :p )
   / welder opinion #10
Naw, just don't set cross legged under something while welding overhead, even though it was the ONLY way I could get in to weld this part. Believe me when I say setting the forest on fire is hard on the trees as well as the rolling stock setting under em... :eek: :(
Needless to say re-applying burn ointment is not an easy task when ya cant get the light of day in the area!! :D :(
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
2012 Chevrolet Impala Sedan (A48082)
2012 Chevrolet...
2000 Ford F150 (A49461)
2000 Ford F150...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
