Weird (?) battery or electrical system problem.
   / Weird (?) battery or electrical system problem.
Update.
The problem appears to have been the relay.
Here is how I figured it out.
I tried the tractor again. As it had a few times before, on the first key turn, I got one click and dash lights, but no start. But subsequent key turns got nothing (not even lights).
I took the 'suspect battery' out and tried it in my other (larger) tractor. It started up immediately, suggesting the battery wasn't bad after all.
I then put an almost new battery in the tractor that wouldn't start, and it still didn't start. It did, however, also show lights and gave a click on the first turn only.
I swapped out the relay and the tractor started right away. I then put the old relay back in, and the tractor didn't start.
I put the 'suspect battery' back in the tractor, with the new relay, and it starts fine.
I got no repeat of the spark in any of this. I can only surmise that there was perhaps a loose connection at one point which got tightened up in the changing of the batteries, although I didn't do anything else differently.
Thanks to everyone for their input!
   / Weird (?) battery or electrical system problem. #32
In the words of Dr Frankenstein "IT'S ALIVE!" and that's the important part. Congrats on giving it life and thanks for reporting back!
   / Weird (?) battery or electrical system problem. #33
Great example of working through a problem via process of elimination!
   / Weird (?) battery or electrical system problem. #34
I would have bet the farm it was the battery, all the classic signs but glad you figured it out!
401 (A52706)
401 (A52706)
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2007 Ford F-450 4x4 Cab and Chassis Truck (A55852)
2007 Ford F-450...
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
