Weight of water
   / Weight of water
Can anyone tell me how much the water might weigh, no bourbon and whiskey involved :dance1:
   / Weight of water #42
Area of a 2.067" ID pipe = (Pii / 4) x 2.067squared
(3.14 / 4) x 4.27 =
0.785 x 4.27 = 3.354 square inches
3.64 gallons x 8.34 pounds = 30.3576 pounds
Someone double check me, please. I've had some Captain Morgan and Dr. Pepper. :drink:
I ran the number you have on my calculator and came up slightly different, so I rechecked by long multiplication by hand and confirmed what my calculator said - 3.35195 square inches. Then I re-did the calculations using pi to 10 digits and got 3.345871574 but since we started with 3 decimal places for pipe diameter, the result should be 3 also, so 3.346 square inches. I went thru and checked the rest and they're all close enough to what I get, it doesn't matter. I end up with a little over 30 pounds as well.
Unless he's talking about two different sizes of pump. Then what he says makes sense.
Or if he's trying to lift the entire water column as a sealed unit.
As for the check valve - there is a little more to it than just the PSI it has to withstand. With a 1 sq inch area at 15 psi the valve only has to resist 15 pounds of pressure. However, with a 2 sq inch at 15 psi the valve only has to resist 15 pounds of pressure just as in the 1 sq inch one, but the rubber diaphram is 2 sq inches so is subjected to 30 pounds - we have to consider "strength of materials" in situations like this.
You will also find smaller diameter pipes rated for higher pressures than larger pipes. A 1" pipe has a circumfrence of 3.14", a 4" pipe is 12.56". So while the pressure is the same, the 4" pipe has to resist 4x the forces because of it's larger surface area.
   / Weight of water #43
If you have a vertical pipe that's 100' tall and filled with water, the pressure at the bottom is about 43.3 PSI. To make water overflow out of the top, you can apply 44PSI at the bottom.
I see what the OP is saying and it doesn't quite relate to the above. He is lifting the volume of water in the space between the large and small pipes on the upstroke. With more the space between the two pipes, he's lifting more water. His physical effort is 43.3 pounds times the area of the water space.
Think of it this way. There are two vertical cylindrical tanks, both 10 feet tall. One is 6" in diameter and the other is 24" in diameter. Both have around 4.3 PSI at the bottom with 10' of head. Pushing water into a pipe fitting at the bottom of either tank at a pressure of more than the 4.3 PSI will make either one overflow.
Now, lift each one off the ground.
   / Weight of water #44
(3.14 / 4) x 4.27 =
Area of a 1.315 OD pipe = (Pii / 4) x 1.315squared
(3.14 / 4) x 1.73 =
0.785 x 1.73 = 1.357 square inches
Volume of 2.067 ID x 100' pipe = 2.067 x 100'
2.067 x 1200" = 2480 cubic inches
Volume of 1.357 OD x 100 pipe = 1.357 x 100'
1.357 x 1200" = 1638.4 cubic inches
Subtract 1638.4 cubic inches from 2480 cubic inches = 841.6 cubic inches.
1 gallon displaces 231 cubic inches
841.6 / 231 = 3.64 gallons
1 gallon weighs 8.34 pounds
You calculated volume of the outer pipe wrong, you should have used the area you calculated in the first step, not the diameter.
   / Weight of water
I plan to use sched 80 at the pump.Thanks
   / Weight of water #46
I guess I misunderstood based on the first post about pushing water.
You wrote: "My intention is to push that column of water from the bottom to the top and I need to know this answer so I can plan the rest of the pump accordingly."
Based on the word push, I believed you were pushing water from a lower location, where your pump was at, to a location higher than the pump. Apparently not?
The link you posted had this description: "I am going to use this to pull water from about 80 feet in my well. No need for electricity to get water any more. People use this setup to pull water from hundreds of feet."
Perhaps that is the reason for the double pipe? Pushing down one pipe to force water up? I didn't realize from the description that water could flow from one pipe into the other?
   / Weight of water
Based on the word push, I believed you were pushing water from a lower location to a higher location. Apparently not?
Perhaps that is the reason for the double pipe ..... pushing down one pipe to force water up? I also didn't realize there was room for water flow from one pipe into the other?
I am still pushing the water, I am pushing it from the bottom of the pipe to the top, I cant help how someone else phrased it on a link I gave.
Its not possible to pull water from any depth greater than >30' with a hand pump
Its no problem for me and I hope I do not sound unappreciative.
   / Weight of water
The second pipe is nothing more than a handle, some would call it the sucker rod but I wont go there. Again its all explained fairly clear in the link I gave
   / Weight of water #49
(3.14 / 4) x 4.27 =
(3.14 / 4) x 1.73 =
I have not had any Captain Morgan and Dr. Pepper but I'm to old to scratch this answer out even with a calculator.
So I use a couple of on line conversion calculators to get the weight of water (at 40 degrees F is just a guess for a well) and the answer I come up with is 86.595 pounds.
First is for a "Tube Volume Calculator": where d2= 2.067" and d1= 1.315" and the length is 100' which equals to 1.3871353296075 cubic feet.
Second is for a "Water Weight Calculator" : where 1.3871353296075 cubic feet equals 86.595 pounds of water at 40 degrees Fahrenheit.
Tube Volume Calculator:
Volume Calculator
Water Weight Calculator:
https://www.thecalculatorsite.com/conversions/common/water-weight.php
Maybe this helps a little and does not confuse the answer the OP was looking for?
Anyway, enjoy your Captain Morgan & Dr. Pepper (I do drink Dr. Pepper),
KC
edit: for the water weight calculator you will have to change the "convert from" to Cubic Feet [ft3], and add in 1.3871353296075 for the volume, and change the water temperature to 40F, and then convert to get the pounds of water answer of 86.595, because the link has wiped out this information.
   / Weight of water #50
No problem. Just fyi, when I read in the first post: "My intention is to push that column of water from the bottom to the top," I had no idea that "the bottom" you were describing was 100 below you down into a well. I'm guessing I'm not the only one who read it that way, as your link didn't come until later. Maybe that explains the wide variety of responses.
Now it is much more clear. Thanks!
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
UNUSED FUTURE 90 PLATE COMPACTOR (A57193)
UNUSED FUTURE 90...
JOHN DEERE CS15 BATWING ROTARY MOWER (A57192)
JOHN DEERE CS15...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2008 Chevrolet 2500HD Silverado 4x4 Crew Cab Pickup Truck (A55852)
2008 Chevrolet...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
