Rear Blade Weight of Implements
   / Weight of Implements #1
olhillbilly
Can anyone give me (Approximate) weight of the following implements. Imco 5 ft Tandem Disc Harrow, 5 ft Sun Burst Box Blade, Covington 1 Row Cultivator, 5 ft Bush Hog Brand Rear Blade, 5 ft LMC Bush hog (Medium Duty) and Fred Cain Subsoiler. Thanks in advance for your help.
   / Weight of Implements #2
There is a BIG difference in certain implements, so it is hard to pin down for sure without looking up each exact model. For example, I have had 2 7' rear blades. No hydraulics or nuthin. One weighed just over 300lbs, and my other is 700lbs.
But here is my best guesses
Disc harrow.............400-600 Depends on angle or box frame and how beefy
Box Blade................400
culivator..................150
blade......................250-300 light duty 500+ heavy duty
bushhog..................500-700
Sub soiler................75
These are just guesses but probabally pretty close. Whay are you needing to know???
   / Weight of Implements #3
These numbers are pretty good and i agree. Im wondering to, any tractor should be able to lift the subsoiler though so im just not shure why this should be a question?
Im guessing that he may be asking cause he wants to tow tractor and all the implements and is just wondering what the total weight may be of them all with the tractor?
I was wanting to know the weight for placement on 16 ft. utility trailer. I have a Dearborn 10-80 that I will place aft of center line of dual axles. My Ford 8 N and Bush Hog will go on first load. The rest I will place on trailer for correct handling of trailer. Plow and other implements (excluding Bush Hog) will go on second load. Thanks for all the help.
   / Weight of Implements #5
Well, those #'s should be close enought to figure what you want.
But keep in mind the size and how much room they take up in relationship to the weight.
For example, the bushhog is your heagiest implement and will take Up 5' of the trailer @ say...600lbs.
BUT, depending on how you load, you can probabally squeeze BOTH the rear blade and box blade into a 5' area, and that may be a hundred or so more than the bushhog in that same area.
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
